Safe One Wire energy transfer by Serbian inventor Milutin Miletic
Started by hartiberlin, June 16, 2011, 11:51:28 AM
alan
Quote from: alan on June 21, 2011, 09:20:26 AM
I think he uses a coil or coils and accesses the 220V as a physical wave, lag the 220V and join it with the 220V input to create 0V, but it's not 0 force or 0 energy?
just a brainfart
Milutin says the same: 0V
I'm going to try this with a AC/AC convertor, which creates low voltage 50Hz from 220V 50Hz.
I think I'm going to give him a call.
hartiberlin
Yes, Alan,
please give him a call, if you can speak the Serbian language.
Please report back what he says.
The phone number was posted a few posts above.
Many thanks.
Regards, Stefan.
IotaYodi
If this device is using zero volts No matter what the input voltage is,then the use of magnetic current may be in order like Ed L used. Instead of doing it by hand it could be done at 50/60hz. There are 3 coils in the setup shown.
Notice how there is no return on the bulb.
What I know I know!
Its what I don't know that's a problem!
FatBird
IotaYodi
QuoteNice drawing IotaYodi
That wasnt me. This comes off Ed L Magnetic Current book. Page 21.
There are only 39 pages to this book. If you have never read it I suggest you download the pdf.
http://docs.google.com/viewer?a=v&q=cache:C5MeCiycpuwJ:freeenergynews.com/Directory/Magnets/Leedskalnin/Magnetic-Current_Edward-Leedskalnin_51pp.pdf+magnetic+current+pdf&hl=en&gl=us&pid=bl&srcid=ADGEESgcrGKwHt7Odo_olzwmQKAMG5gKJ0tJKScOQvtqlIycn22Avtk3nzCObQr2WeQhgq5NCnJW-8bQOWwcKZyORldVuooQ1YEx2pYtySs1JoHqOfdtE-4ShMeElRpk6DuP6XIVLMCm&sig=AHIEtbSpqAXpaWgOQCUz7MCb8wwL17NbHQ
Im in agreement with Stefan here. Its dipole flipping just like the Ed L experiments. The 2 main bus bars alternate back and forth and are 180 degrees out of phase with each other. At any given time the addition of both Voltages equals zero. Seems he is alternating magnetic poles on the single wire. Normal current flow is always from south to north with the north magnetic field being the output. Sure would like to know how the normal current is isolated.
What I know I know!
