Eddy currents and their implications
Started by frankly, July 08, 2011, 04:04:57 AM
TEKTRON
Quote from: MotovilovDN on July 09, 2011, 01:15:34 AM
Ð' обласÑ,и изучения свободной энергии сущесÑ,вуюÑ, несколько пуÑ,ей для еÑ' понимания.
1. ЧисÑ,о научный пуÑ,ÑŒ. ЭÑ,о более глубокое, чем Ñ,радиционное, знание законов Ñ,,изики.
2. ИнÑ,уиÑ,ивное познание.  Человек делаеÑ, свой прибор Ñ,ак, как ему подсказываеÑ, душа, Ð'ог. То есÑ,ÑŒ Ñ,ак, как ему прияÑ,но и  гармонично видеÑ,ÑŒ свой будущий генераÑ,ор энергии.
3. МеÑ,од образного понимания досÑ,ижений другиÑ... консÑ,рукÑ,оров - Тесла, Ð"рицкевича, СÑ,ивена Марка.  При эÑ,ом можно пыÑ,аÑ,ься на уровне чувсÑ,в поняÑ,ÑŒ карÑ,инки прибора.
4. СисÑ,емный подÑ...од, когда консÑ,рукÑ,ор обладаеÑ, способносÑ,ью комплексного видения всеÑ... Ñ,Ñ€Ñ'Ñ... пуÑ,ей сразу.
Russian to English translation:
In the field of free energy, there are several ways to understand it.
1. Purely scientific way. It's deeper than the traditional knowledge of the laws of physics.
2. Intuitive knowledge. Man makes his instrument as he tells the soul, God. That is, as he pleasantly and harmoniously to see their future power generator.
3. The method of imaginative understanding of the achievements of other designers - Tesla Gritskevich, Steven Mark. One can try to understand the level of feelings Pictures unit.
4. The systems approach, when the designer has the ability for an integrated vision of all three ways at once.
frankly
Hi there Z monkey. Useful observations you make, regarding loss in a system. However, WHAT MAKES A WATT METER TURN? Eddy currents.
So, what are these "connected to" to provide the lever to turn the disk?
How can this be done with certainty, anytime of the day or night, anywhere in the world?
"The metallic disc  (which is aluminium)   is acted upon by two coils. One coil is connected in such a way that it produces a magnetic flux in proportion to the voltage and the other produces a magnetic flux in proportion to the current. The field of the voltage coil is delayed by 90 degrees using a lag coil.[17] This produces eddy currents in the disc and the effect is such that a force is exerted on the disc in proportion to the product of the instantaneous current and voltage. A permanent magnet exerts an opposing force proportional to the speed of rotation of the disc. The equilibrium between these two opposing forces results in the disc rotating at a speed proportional to the power being used. The disc drives a register mechanism which integrates the speed of the disc over time by counting revolutions, much like the odometer in a car, in order to render a measurement of the total energy used over a period of time."
From here:  http://en.wikipedia.org/wiki/Electricity_meter
So, although in some instances, eddy currents are wasteful, it is only by convention. When they appear in a coil, they generate energy.
It is in fact the source of so much trouble to valves. The oscillation of the valves can innitiate on the power side, eddy currents, destroying the gate if not clamped with condensors.
ramset
Frankly
Good stuff!! I love your "Vision" of the Energy around us and how you explain it!
I believe it was bolt [a member here] who said "A dipole by nature is OU as long as you don't "Touch" it" [doesn't that suck].
Z's analogy and your "insight" definately paint an interesting picture!
Please be patient with those of us that Don't "see" so easily.
I'm from NYC , USA  I struggle thru life making Purpose built furniture for children with special needs,[mostly Autism and Downs syndrome].
I wish I could see the world the way you do,I know I could do a much better job if I did.
Frankly
"they Generate energy"?
I like the sound of that!!
More Please.....................
Thank you
Chet
Thanks Grandma
frankly
Hi Chet.
Yes, eddy currents are the source of energy on a macro scale.
Within the center of atoms, the unit particle swirls and dances it's signature pattern, determining the nature of the atom it forms. This dance is called vibration by modern science, for as I have said, with modern equipment, I think we only see a part of the path of the particle. This dance is/can be fractaly advanced once it's nature is understood.
Life does it without thinking. It is a part of nature.
Human ingenuity can do it too.
There is a simple pattern, a mode if you will, to allow this. It is spoken of by Ed Leedskalnin, as his "Sweet Sixteen", (4 * 4) or by Eric Dollard, who uses 1/4 wave harmonics of the nuclear magnetic resonance of the target dipole, without even realising that is what he is doing. Or, even Tesla with his rotating magnetic field. Achieved only by correct "tuning" of the oscillations and application of equal and opposite magnetic fields, locking onto the target dipole's rotation and increasing it's speed of rotation, thereby, adding E into E=MC^2.
By this manner, we can truly amplify energy. Using the "lever" that supports the existence of matter, the "Wheel-work of nature" as Tesla put it, we can increase, by an exponential amount, the input energy, delivering into a load, 10^13 times more power, for the activated mass's reactance energy, if Beardon is correct.
Does any of this make sense?
Does anyone have the capacity to do the experiments I described?
What thoughts or "aha" moments have been had?
I need feedback.
What is it that is needed? I need to "see" that people are thinking. Or else, there is no learning. Only indoctrination. This is not the way. You each have to understand the process for yourself. From your own referance point in the universe, which is unique to each. To each their own.
I am not going to "give away" 17 years of my life for someone else to squander. It is not just my sacrifice that has been made, but my family also.
So, what thoughts, reflections, apparatus, processes, will lead to a resolution that can truly be called a "group effort" which can we achieve, for everyone, and our children?.
I am actively building, but it is slow.
Without help, it is hard.
I hear that there is a large amount of people in the world, clamouring for a better path. I think I see the way. It is one of togetherness. All of us, raising our potential together, as one. Tesla said, "Let them have the now, for the future is mine". I like to think he died with a smile upon his face. A smile of knowing.
Let these people that are out there, come here. If not, let them help. Only together can we make a difference. Commercialism leads to destruction. Socialism to corruption. Religion to war. Together, we prevail. Let us be one. Together.
Let's build the device that shows this capacity....to link with the "god particle" within us all, that part of us that links us each to everyone, and all to each other in every place, every time.
A worthwhile pursuit?
z.monkey
Quote from: frankly on July 09, 2011, 05:28:22 AM
Frankly, you have a unity based perspective...
The Oneness that I know.  Indeed, We are One...
We are all basically just bits of Gaia, like skin cells...
Goodwill to All, for All is One.  It is a true spirit based
perspective that the Dogma oriented philosophies do not
understand.  We must listen to our Mother, Gaia, and
bend to her will if we are to solve the problems that
plague us.  Contemporary solutions have run their course,
and it is time for new solutions that are really very, very
old solutions.  Energy is unlimited, everyone deserves their
equal share...
Goodwill to All, for All is One!
