Beck Blood Cleanser
Started by AbbaRue, July 16, 2011, 12:46:00 PM
AlienGrey
 No, you are quoting from the obsolete information!
So one version has a tumor zapper coil have you got that bit?
are you driving that with a square wave?
Where did you find that one op-amp square wave generator circuit from that isn't in the BB hand out
you didn't get that from me mine does not have any relay anywhere near it!
I can use the device to make colied silver according to the info but it's not enough voltage to do it correctly
you need over 2000 volts or a modified microwave to do it correctly.
Have you found his old internet site with the updates and his other circuits?
There is also a cost to coast interview as well somewhere about a good ten years ago.
https://video.search.yahoo.com/search/video?fr=mcafee&p=bob+beck#id=58&vid=050d078ae77242ccd40b0885256d2b1a&action=view
e2matrix
The Hulda Clark type zappers use square wave pulses and are positive only.   I've used a couple of them for years and they do work very well.   I would think a square wave is better at killing parasites than a sine wave.
promixe
Quote from: AlienGrey on April 26, 2019, 10:29:50 AM
As I suspected we're talking about entirely different devices. You are referring to Bob's PEMG "Magnetic Pulser" device, which is a high voltage (~340VDC) and high power (~400A) air-core electromagnet coil driving device. This thread is about Bob's "Blood Cleanser", which is a low voltage battery powered portable wrist worn device. Neither of these devices are driven by a sine wave though. The "Magnetic Pulser" works off of AC mains and charges a bank of photoflash capacitors, then discharges them through a coil. Pulse rates of that device are very slow (2-6 seconds per pulse). What is most important for that device is the rate of change, i.e. how quickly current rises/falls, not how often the pulses are triggered.
The "Blood Cleanser" also relies on the rate of change, not on the frequency of the pulses. Because of this it uses a square wave, where the rate of change is as fast as possible and the frequency of the signal is not greatly important as it would be with a sine wave.
Pages 3 and 6 from the official Bob Beck website - https://www.bobbeck.com/pdfs/build-your-own.pdf
Page 19 of the original Bob Beck handout - http://the-eye.eu/public/concen.org/Bob%20Beck%20Protocol%20Blood%20Electro-Purifier%20Colloidal%20Silver/text/Take%20Back%20Your%20Power%20-%20Bob%20Beck.pdf
Also, page 21 of the last link has the original relay version of this device. Both schematics of this device output a square wave AC waveform.
It is the schematic Bob shows in this video - https://youtu.be/h6b5IFzBm6w?t=829
Also 1st post of this thread has the same schematic, drawn differently.
AlienGrey
No, i didn't make the coil zapper device but perhaps you can and let us all know if it kills the Monsanto toxins or not.
