Aether and what it is.
Started by jbignes5, July 26, 2011, 03:13:51 PM
aromaz
@jbignes5;
The problem I personally have with your arguments are numbers.  Depends which glass you want to look through - all numbers are important.  You say # 3 for many reasons but let us look at some other numbers.
The number two is all present - opposites, polarity, good vs evil, light vs darkness.  I would say there are more of a two in any ancient writings than any other number.  What about #4?  Most temples were build with four sides as were pyramids all over the world, many cities, castles even houses.  Often houses were actually circular - the concept of Zero though they did not see it as such except in Africa.
Is Seven not the sacred number?  The whole Talmud, Bible, Bagavatghita and Koran at least is filled with seven as numerical value.  Six on the other hand is usually reserved for death, satan.  In Buddhism six is the very bad unlucky number.
Eight which is 2x4 is not so widely used except in the biblical new testament where it is the number of Christ.  However, when you rurn the 8 on its side, you find it in all other traditions - the symbol of infinity.  How about nine?  3x3 or 3+6, 5+4 these shows the ultimate of binary. On its own it is seldom used.
There is one more critically important number which is not a single digit - except in Buddhism.  #13. Though many consider it the unlucky number - it has extremely powerful connections.  This is the number of the most powerful angels (Christian, Jewish and Muslim) - The scribe of God; who happens to be a human man.  Be it Imhothep. Enoch, Joseph, or whoever - his name is Metatron.
Even in Christianity - 12 disipels PLUS Jesus = 13!
Judaism - 12 months in year, but some years has 13th month - to bring balance between dates and nature.
Jackob had 12 sons of which one is Joseph; the one who saved all his brothers, without him Isreal would not exist.
Yet, his name does not occur as a tribe in later chronology?  In stead two of his sons are present Mannasse and Ephraem.
Metatron is the 13th; that is the one seldom seen although he is more important that the other 12 usually seen.
(To continue)
aromaz
. . . which brings me to the most important statement you can ever get; "The forces of nature is not singular - it is a harmony of many shapes"  If you are looking for the most important geometric shape, or most important number you are destined to fail.  THAT is the single biggest problem we have in science today.
Metatron has his own scared geometry which consists of 13.  Google 'Metatron Cube' and you will find many variations.  Within the metratron cube you find the numbers 1,2,3,4,5,6,7,8,9,12 and 13 with ALL geometric shapes embedded.  A uniform, all present, all encompassing single FOUR DIMENSIONAL object - it even reflects all from first, two, three and fourth dimensions and from there you can see the all important picture of everything we need to know.  also we can see all the mistakes ever made in science to this day.
Remaining is only one more pointer to make.  However much you are seeking a shape or form, you will always find there is only one. It is the spiral, vortex - or should I say - it is the Golden Ratio.   1.618.   The golden ratio has the Fibonachi and phi elements, it has all the elements of all geometrical shapes - and that is the ultimate shape you will find from small miniscule life forms through to the shapes of Galaxies - and everything in-between.
Aether is not a shape, not a number, no mass, no energy - it is a pure non-existing all present paradox which is the origin of everything.  In the Metatron Cube the Aether is also the sphere in the centre, the one on its own is only a void, point of origin - also the centre of nothing.  Without it there can be no cube, no triangle nor anything else.
Within water you have all (crystal) shapes, as you can see in snowflakes.  Within ALL elements you have all possible numbers of geometric/crystalline shapes.  In Hydrogen for instance we find - Hydrogen (Protium), Deuterium, Tritium, Quadrium, Muonic Helium, Hydrogen Pentium, Hydrogen Octium and even 7H. To date no higher isotopes were observed - yet.
The Aether is present in ALL shapes, 2-D and 3-D; but it is the new dimension of this 21st century.  That will be our lessons in this near future, the change of 2012 Batuun.  We will come to know about the FOURTH DIMENSION.
In all shapes the Aether is the fourth dimension - the centre point of the complete shape.
But there is a paradox:  The Fourth Dimension is also the ZERO dimension;
from the nothing (Aether) came every matter and every matter is holding the aether within itself.
Yes, fractal to the interior until you reach - the Aether; infinity.
Rather than trying to apply geometry, I would suggest looking at the application of FRACTALS at the GOLDEN RATIO when you are seeking answers; and seek to know more about the Aether.
jbignes5
 You will not find me disagreeing on your statements about the numbers. But one thing is clear the genesis of all matter seems to point to the 3 and 6. 3 being the base and 3*2=6. I am not saying there is no other numbers associated with the MASS of these particles, meaning in Masses these particles can form any shape and combination. It could be that the higher numbers are harmonics of these base shapes of 3 and 4. I do believe that 3 and 4 are the base numbers. And any combination of those equal the harmonic collections or masses of these particles.
You brought up a good point and I hadn't thought of that yet because I was trying to focus on the basic aspect of this medium. In order to get to the basic aspect I took what appeared in the macro and worked back to the micro and below. Because this appearance of the basic shapes and geometry bleed through the macro scale I am thinking this is the fractal connection.
I saw a very interesting experiment on the show "Through the Wormhole". It was with liguid silicone on a vibratory plate of liquid silicone. By using a tooth pick they could dip into the silicone and produce little drops that never would touch the vibrating mass of silicone that was vibrating. So it bounced like rubber ball on a very elastic membrane. The bouncing caused a standing wave pattern in the trembling silicone and it acted much like what I have described in my talks here. The standing waves guided the ball of silicone especially when other balls were created. I'm gonna see if I can find that video online. It completely explains what I am seeing for the atom and the action of the medium.
I'll edit this if I find a link...
Ok found it!
http://www.youtube.com/watch?v=toebBv_fAe8&NR=1
Now in this case we could say that the surface of the fluid is the medium of aether and the drops are the atom.. The only thing is the medium is 3 dimensional. It quivers and the matter inside of it gets its energy from that. The problem is the quiver is super fast because the medium has no real limits like light does. The standing waves that matter causes is because of inertia of the matter in the mediums density. We can see this effect on the macro scale of our Universe but it is much harder to see on the micro scale because the density of Aether is so vast and moves instantly. I know for a fact that this is the reason matter behaves the way it does.
Here is another experiment that shows what the dual slit experiment is actually doing knowing this new information.
http://www.youtube.com/watch?v=GHHaDWEWtQE
We have a lot of restructuring now to do to our know physics. We must admit that the ancients and our forefathers knew more then we think we know now. Why did they know more because it was so simple it was staring them and us in the face the whole time. We just like to make thing so complicated that there is no way we could figure this out.
So Tesla was right all along. Standing waves are the secret and matter is tightly integrated with that standing wave. The more Mass of matter the larger the ability to convert that minute vibration into real energy. Because Matter has the Aether in it the matter acts like an anchor and ties inertia to the medium through it's connections in the matter and dampens this vibration that the Aether has. Think of it as a Super giant bowl of jello and then place marbles on it. When you vibrate the jello it will move the marbles without having to apply direct energy to the marbles themselves. Of course the marbles will not have the same rate of vibration as the medium it rests on because of inertia. Thats the 2d representation. Now think in fluid 3d.
aromaz
We have a problem; we can't continue to work on assumptions or what we think from what we think we see.  Take for instance yourself.  When you walk, drive, ride on the road; what percentage of Blue Toyota Camry's do you notice?  Now, let us assume you buy a blue Toyota Camry - suddenly you will see so many more on the road.  I just went through a similar experience here in Thailand with the old 'Singing bowls'  I love them.  Been here for 12 years and very seldom see any.  Then I started collecting them - because they are quite rare; well that is what I thought.  Now that I am building a serious collection I find more and more at almost any and every market / auction I visit.
If you are looking for the THREE's you find them more than SEVEN; if you are looking for the SEVEN, you will find them more than THREE's.  Be aware of your own perception.  When you are healthy, few people has cancer; when you are diagnosed with it, suddenly one out of twenty has cancer ! ! !  What changed, definitely not the number of cancer living people.
THREE - yea it is an important number.  Similar to Tesla I do count often in threes.  I hate to go to the computer centre here in Pattaya - every time I do go there, such visit is forced-followed up with two more; every time problems with computer!  Always three.  But is it correct that THREE is the number in geometry?  No it can't be, geometry can't be 2D - so at least you must have four corners, four sides - that is FOUR?
The Pyramids does not have any three in it - they are not two Dimensional.  There are 5 corners, 4 sides, 5 planes, 8 edges and each plane has three edges.  Unless off course you take the pyramids with mirror image where you will have 6 corners, four sides, 8 planes, 12 edges . . .
In life we say we humans have the Body, Spirit and Soul - three?  God manifest in three - Father, Son and Holy spirit?  These are all WRONG!  There is no three.  God is One. The human is one. Whatever the components are, all together forms one and they are more than only three components.
By the way, try to imagine a six sided three dimensional object.  Is it not a Cube?
Horrible as it might sound, my respectful advice is to forget about Nassim Haramein and his concepts that NEVER achieved anything but confusion.
There is no base number - unless you will accept ZERO.
All existence are shape and dimension - from origin to existence and back to origin;
Again, have a look at the Metatron Cube - and build yourself a 3D model.
Quite an interesting experience, VERY educational and amazing assesments will follow.
aromaz
What I see is resistance; resistance that is caused by sound or gravity.  I have the same effect on water with my singing bowls.  Vibration of sound prevents merging, droplets dance on the surface.
If you want to look more into Aether you have to consider the origin of matter.  Aether is the ZERO, the base; the origin of all matter.  Thus it can't have any properties of matter. It was and is there before the matter.  You can't compare aether to water - that is wrong.  It is not a fluid dynamic, it is not an energy, it does not have any properties.
To understand Aether - you have to compare and think of Aether; not matter.
Aether is not polarized; therefore it can't be measured or observed in any way known to us.
When Aether is 'charged' or modified by the 'Sound'; 'Light' starts to form, it starts vibrating, becomes polarized and have a barrier between the two polarities.  THEN it can start to behave like matter and it can be observed and measured.  Only after it becomes polarized can it cause any effect on or with matter.  Only then can it be seen as 'the fabric of space'.
There is no big mystery about space or the so called fabric of space.
'Fabric of space' is a combination of electrical charge and gravity, the later due to disassociation of matter.
This is the cycle of existence:
Aether
Sound
Light
Polarity (Electrical and Motion)
Matter (Magnetic)
Gravity (Decay)
Dissasociation (Radiation)
Seize of Motion
Seize of Polarity
Release of Light
Aether
Where the 'Sound' and 'Light' is not to be confused with Electromagnetic phenomena.
These are from a different origin, yet to be properly defined other than to say "God".
>>>>>>>>>>>>>> EDIT
Of course there is the other Aether - the one that is measureable with instruments; the one we use to send radio signals and shockwaves through.  That aether is a mixed soup of Electro Magnetic Gravity Energy.  I personally do not consider this the Aether as per original definition.
