Aether and what it is.
Started by jbignes5, July 26, 2011, 03:13:51 PM
onthecuttingedge2005
Aether doesn't even begin to work until 1,016 Tesla or above until the magnetic field strength is satisfied.
this was recently discovered, virtual particles can now be trapped into existence.
it is about how much energy you have to play with period.
you all think on small terms of energy and just not enough to confound relativity.
jbignes5
Quote from: IotaYodi on August 02, 2011, 09:55:14 PM
Its not water.
Really. Then water as I should have said contains more of the condensed Aether then most other matter we can look at except for crystals like diamond and quarts. When I say condensed it means there is extra Aether that has collected there in between the water molecules. Does that help you to understand?
The Aether is not virtual either. It is very dynamic yes but the base particles are very real. Just because they are to us invisible to our eyes does not make them less real. Because we can not see the center to the Blackhole does not make it less real. It is after all consuming matter and we can see that. We have to look at the effects and then we can see the origin.
My thinking on condensing is that after a conductor looses it's charge or depletes a portion they can float down from the network and reattach itself to water. This gives water extra places to attach charges or network connections within it's own mass. The boundary layer is actually made up of these extra conductors and they filter into the water as the water circulates twords the surface. Water molecules pick up the extra conductors in this process and float to the bottom because they now lack charges but have more receptors for new charges. This makes them heavy in the sense of molecules and they sink to the bottom.
At this point on the molecular scale, like particles tend to harmonize with other like particles. This causes a standing wave around the particle as the medium of Aether is vibrating and this standing wave is merely like the cymatics I referenced earlier. The medium of Aether bunches up around the particle making it look like it has a shell, more commonly called the electron cloud. This bunching up is only the medium of the Aether itself. But these collections of medium have great power in conducting charges twords the potential or charges contained in the matter shell of flakes. The flakes of matter are what gives the internal charge it's frequency based on the matter flakes size, shape and even dielectric strength. Harmonies form from all of these components and a particle maintains it's uniqueness because of that frequency and the other laws at that level. The shells are completely capable of traversing the shells and the less dense areas because of charges that get attracted to the internal charges potential via the pulsing of the matter flakes.
If there is one thing you learn I would think that flows are the "Energy" of the universe. Learn how to intercept or divert that flow and you have a never ending stream of energy from nature itself. We now know that if you have super high voltages and very little amps you can transfer energy with out loss or very little loss. It was the one gift that Tesla came up with. If you are having a hard time getting power to the designated spot then just raise the potential and the current drops. Feed that over the same conductors we use on that scale and bingo near unity energy support. If you then lower the potential in the device then you get nearly all the force inside the zone of transformation. If we let induction happen and down convert that potential in the device itself, like a motor then you get more then you had to supply if you transmit the potential first in the air to the receiver then pump that potential into the device to transform into real current of the motor you get extra energy picked up from the network you are pulsing which would be the Aether when used via standing waves.
The problem has been of materials that react to the Aether and that have extra Aether to carry the collected extra charges. Since Tesla was working in the fluid pump design he learned a lot about water and it's ability to transmit these charges to exactly where he wanted it. In fact I and other have done experiments about Water and the capacitor like effect it has. Even when left alone to it's own ability it seems to recharge on it's own. If we use this like Tesla figured out then water could be the super conductor of these powerful charges. If stimulated properly they could collect and store much more charges then any other device made by man and it energizes the water we would use bringing our environment back to the way it was by boosting it's ability to recharge the environment.
I think aluminum is that material. I suspect when aluminum pipes are used it would extract this energy of charges and deposit it to the water that flows in it creating a turbo battery like effect. Simply hook your motor between the cyclic pipes and use a ground. Even a virtual ground will work like the body of a car. This would allow the body to spread out the charges and rejoin the cycle. The faster the water the higher the potential and the more charges it can collect. I could be at that point we need to direct the collection points like where the radiator is so that an increase in the flow of the air around the pipes increases the amount of ambient charges it will collect. Obviously a pulsing high potential signal will need to be used to stimulate the free charges to collect in the water cap. a one way signal. Thats where diodes and caps are for are for. I would prefer to use a spark gap and that will make this very simple.
This is the same process as Dr. Stiffler has shown. But I believe that his process doesn't work well or as good as it should because he doesn't use a clean diode like effect. With the spark gap that is near perfect on via the break down of the air between the gap. This break down is actually more conductors being attracted to that space. The extra punch it gives is not because of the braking down but because in the instant of a micro second it conducts and goes way faster then it should. Ozone I believe is a result of the conductors being super saturated at that point in space. <Not sure about that statement.
It might be that we have to stimulate the water inside the aluminum pipes via an isolated electrode with fluid dynamics design into the electrode to facilitate the fast cycling of the water. This way the aluminum is not directly connected to the aluminum reducing the risk of shocks. They should be very rounded electrodes that allow for the higher potential to not penetrate the water as easily.
forest
I thought Tesla said ether has gaseuos  form ? Tesla also stated radio waves are longitudinal and Hertz wave do not exists.
Exceptionally strange it sounds but my advice : do not disregard Tesla statements. He proved all experimentally. In 1890 he sent energy of few HP to devices using Hertz waves tuned to his body capacitance, but later (after 1895) he used only longitudinal waves.
raburgeson
Study him some more and check out the statements about 3 dimensional lattice. The aether is a continuous flow of energy. The only thing that seems to offer resistance to the flow is a wall of frozen ether. See stiffening the aether with high voltage static electrical fields. What it is exactly I can't say. I think Maxwell and Tesla fully understood. I would be great to go back to the time they went to school wouldn't it.
If true hertz waves exist then  we could apply his theory of oscillation to them. It doesn't work. He didn't mean hertz waves don't exist altogether, he meant they don't exist as the standing scientific definition. I (think) he was implying that there is something very wrong about the description of the wave. You might like to check what Gabriel Kron said about electro-magnetic waves. Unfortunately the US government told him what he was allowed to disclose. Take for example the negative resistor he discovered. He was told to describe material as if only one element displayed negative resistance properties. For one you can add to that list iron.  There are some oxides that show some super conducting and negative resistance also. We know now that palladium has been manufactured impure to make cold fusion stay on a shelf. Without pure Palladium you can't make it work. Just a modern day example of the government hiding the truth or interfering in behalf of the to big to fails. They did this in Tesla's days too. They didn't control Tesla himself, they controlled his financial backing. If he had took it to court and made everyone pay as agreed per Horse power, Walden Cliff would have been built and the to big to fails wouldn't ever have existed.
Tesla's work is still top secret. That's an indication that it is really worth trying to understand, good luck.
jbignes5
 Yes well they are longitunal. But you have to remember the Aether planes are waving. It is the same process that happens all around a black hole. He creates a wave that looks like the sign wave on an oscilloscope but it radiates out from the center of the disturbance. The ripples in the Aether carry extra conductors back to the source. Think of it as a pond that is smooth and calm. Then start a drop flow in the center of the pond and all kinds of action radiates and rebounds all over the place.  Put a body that floats in the lake and it will toss to and fro. Sometimes so strong  a force that it rips the body apart. The potentials he used were so incredibly high that near nothing was lost in the transmission of this energy and the body would tend to absorb most of the disturbances. Kinda like the action you see around an island. where the island looks like the ending place of all the action around the island.
We kind of use this process already but it is inside of a coil. With the coil being the body in the pond. The only difference is that in Tesla's method the body has very limited effect on the source after the source has discharged.
In our futile attempts we usually don't get the process right and the cycle ends up being in the circuit. You need to stop the back flow twords the source so that the capacitor has time to refill without being effected by the feed back. This is another reason Tesla used magnets to "quench" the gap. Meaning it had to fight to get through the magnetic field and this also magnified the effect as well because of constriction of the arc space via magnetic field. I saw a demonstration once of a guy who took a ring magnet and allows a high voltage spark near the center of the magnet. It spread out from the center and followed a flat plane till it hit the magnet. It looked like an electric disk. Very even and very interesting. This process of "Quenching" is much the same as the hose and water nozzle version of my talks. Compressing the energy raises the potential even further and draws more to the conduction path. It could be that he put some sort of antenna buds around this area to lead charges into the system for an extra boost.
His motor was also a very curious thing indeed. I think Tesla figured out that when you generate from very fine wires from a magnetic field you get very high voltage. Since this voltage has no real current it's kick back is very small as we are finding out. This High voltage generator was on the same shaft of the generator(magnet)/(Generator field coils/starter motor)/ drive motor. With his design of the ac induction motor it allowed the conversion from high voltage to lower voltage very high amps in the generator winding. If you shorted the winding the Generator field coils would operate normally like a standard induction motor but if you opened them  and fed them to the drive motor it would assist the whole process and drive itself as well as any load you wanted. In fact this motor ran at a standard speed and when you tried to retard the shaft it generated even more current. He said it was impossible to stop except for the fact that the winding could not stand that much current and usually developed a short if it was retarded to much. This motor I believe was patented and worked on the principle of the Aether or the antithesis of our magnetic system, or in reverse of our system. I have posted many links to this patent and will do so again if anyone wants to see it. The central rings around the rotor are Torrids with single layered coils split into 1/4 of the ring. This way the magnetic field is trapped into the ring and only the electric field is allowed to play with the generator coils. I'm in the process of attempting to build one. Should know if it works in a few months. I got a frame built ac motor that I am gonna get shaved down into a ring or round stock for the torrid. and use the core as is. I just need to make a break in the rotor coil so that I can open and close the coil to create the effect. I am also thinking that I could get away with a motor that has a lid that has two halves of the torrid. A split torrid would act like a PMH of eds once energized and hold itself together. This could make designing and building the motors very easy and working on them very very simple.
