meyers vic
Started by illuminati, August 14, 2011, 09:50:47 PM
Doug1
Wouldnt flux core welding wire work if you coated it with an insulating layer.It comes in a lot of different sizes and it likes to roll up tight being sort of stiff.
  You uncovered some interesting info that makes me wonder about transformer development.
illuminati
the best link for wire i can find i have given you, it is cheap, not ideal but works, welding wire as far as i know has problems. it is the science thrown in that should  get you thinking. read and think is all i ask.
crisssm
If the real deal with the vic is the iron wire and the spin of the electron ,then the tubes mus be build from magnetic material like ss304  not 316l like every body does because the 316l is non magnetic and wil lose the spin propriety of the electron.. . no??? Stanley mayer used in his design ss304.   Maybe the all thing is the polarized curent and the high voltage for the vic . I have tried to make the polarization of the water without the vic ,only with 2 flyback transformers from monitors with no succes the current was 0 and the voltage was about 15-20 kv and nothing hapened, i varied the pulse freqvency from 200hz to 200khz and nothing .whitout a little curent u canot bring the voltage up in the water thats for shure .So i will try ss304 and iron wire transformer to see if the spin of the electron (or polarized current) will make a diference.  Anyway look at http://www.overunity.com/index.php?topic=10466 it is conected with this teory and http://www.rexresearch.com/ehrenhaf/ehrenhaf.htm maybe we will conect them togheder somehow and understand what is realy hapening
P.S. sorry for my bad english
CompuTutor
The SS issue is an old and often misunderstood one.
here are some interesting viewpoints as example:
http://www.finishing.com/112/70.shtml
illuminati
hi lads
the tubes are a seperate issue, they have  a chemical reaction explained here
http://www.scribd.com/doc/16642199/WFCexpl
the hi voltage comes from this reaction. use 304 or 316 it makes little difference in this case
the vic needs to be made of iron wire for the reasons i have explained, the voltage out triggers a chemical reaction in the wfc.
secondary and chokes are wound as the vic matrix patent says (this i believe is the design for injectors) the reason i use this design is the primary can be removed without unwinding any other coils,secondary and chokes do not have to be wound perfect. primary has to create a perfect magnetic field.
the 8xa design is better for use with a wfc, but harder to build.
make sure you understand what i have posted to save time and effort in the long run
meyer and Felix Ehrenhaft technologys will not mix.
