Confirming the Delayed Lenz Effect
Started by Overunityguide, August 30, 2011, 04:59:41 PM
mondrasek
Quote from: Overunityguide on August 31, 2011, 05:11:52 PM
I have removed the generator rotor, so the shaft only was turning.
@Overunityguide, when you removed the generator rotor, you also removed all the air drag that the rotor, and especially the projecting magnets and retaining screws, creates.  So this would result in decreased power consumption.  So I don't think you can compare that 66 watt reading to any of the others.
Did you test WITH the rotor, but WITHOUT the coil?
Thanks,
M.
Overunityguide
Quote from: mondrasek on September 01, 2011, 10:31:05 AM
Thanks,
M.
@mondrasek,
I have just tried it and with the rotor, without the coil it runs at about 68 / 69 Watts idle on 3000 rpm
With Kind Regards, Overunityguide
Confirming the Negative Lenz Effect:
http://www.youtube.com/watch?v=kzxc3Ai4T3A
Overunityguide
After A couple of people asked for it digitally, here is my schematic
Thane C Heins Replication, Confirming the Negative Lenz Effect: http://www.youtube.com/watch?v=kzxc3Ai4T3A
minde4000
Quote from: Overunityguide on September 02, 2011, 03:41:20 PM
I have this kind of setup with high impedance single wire coil and bifilar coil and up to 3600 rpm driver with 18 NS magnets. Nothing special... You could follow thread on TC Heins device replication attempt. Me and at  least a couple of other replicators didnt get much. Accelerations "effect" is also simply explainable trick.  8)
Minde
teslaalset
@Overunityguide,
Can I ask you for a calibration measurement?
What is the actual power consumed when the whole coil setup is removed?
I am asking this because if the coil units contributes to let say 5 W of extra losses (e.g. eddy current losses in the core of the HV coil) and you notice a power drop of 2 W when connecting the load, you will still end up with 3 W of losses and this will be a very misleading experiment.
Thanks in advance,
Teslaalset,
Fellow Dutch forum member
