Confirming the Delayed Lenz Effect
Started by Overunityguide, August 30, 2011, 04:59:41 PM
CRANKYpants
Quote from: gotoluc on October 07, 2011, 04:44:52 PM
Green Probe is Current across 1 Ohm and Yellow probe is Voltage
VOLTAGE = PRIMARY VOLTAGE?
QuoteFirst Scope Shot is Ferrite Toroid Primary @2MHz with Secondary Open
POWER FACTOR IS NOT GOOD, I.E. ALMOST 1
QuoteSecond Scope Shot is Ferrite Toroid Primary @2MHz with Secondary on 22 Ohm Load
CURRENT DEREASES BY 50mV OR 6.8% WHICH IS GOOD  :)
POWER FACTOR SHIFTS BY ABOUT 10 DEGREES TOWARDS 1 BECOMING MORE RESISTIVE = NOT SO GOOD  :-[
SOME OF THE LOAD PF IS BEING REFLECTED BACK ONTO THE PRIMARY.
QuoteThird Scope Shot is Ferrite Toroid Primary @2MHz with Secondary on 22 Ohm Load with Voltage Probe across Load
PRIMARY VOLTAGE AND LOAD CURRENT PHASE ANGLES MEANS NOTHING HOWEVER IF YOU CAN MOVE THE YELLOW PROBE TO THE SHUNT (PRIMARY CURRENT) THIS WOULD TELL US WHAT EFFECT LOAD PF IS HAVING ON THE PRIMARY... I.E. IS THE SHIFT 10 DEGREES AS ABOVE?
THE ONLY THING THAT IS OF ANY RELEVANCE IS THE PRIMARY CURRENT AND POWER FACTOR. MOST IMPORTANT IS THE SHUNT PROBE - REMOVING THAT REMOVES OUR REFERENCE POINT FOR OBSERVATION.
GOOD SCIENCE IS GOOD OBSERVATION AND YOU NEED A 4 CHANNEL SCOPE IF YOU ARE GOING TO BE MOVING PROBES AROUND BECAUSE WE NEED TO MAINTAIN OUR REFERENCE POINT. (THAT IS WHY I AM BRINGING YOU MY SCOPE TODAY... IF YOU ARE NOT OUT SAILING?)  8)
CHEERS
T
ramset
SAILING??
NOBODY TOLD ME THERE WAS AN OVER NUDITY  SAILING TRIP!!
:P
Chet
Thanks Grandma
CRANKYpants
Quote from: ramset on October 08, 2011, 09:11:31 AM
SAILING??
:P
Chet
YOU HAVE SOME BATHROOMS TO CLEAN FIRST MISTER!
WE MAY HAVE GUESTS COMING OVER FOR THANKSGIVING DINNER.
T
ramset
GOOD ............
Swab your own decks,See If I care!!
Sigh.....
Overnudity sailing one of my last Vices.............
Chet
Thanks Grandma
CRANKYpants
Quote from: ramset on October 08, 2011, 10:16:10 AM
GOOD ............
Chet
AFTER YOU ARE DONE WITH THE BATHROOMS YOU HAVE TO CHECK ON OUG TO SEE HOW HE IS DOING WITH HIS CHORES  :P NOW THAT HE IS HOME FROM HIS "BUSINESS TRIP".
CHEERS
T
