Confirming the Delayed Lenz Effect
Started by Overunityguide, August 30, 2011, 04:59:41 PM
gyulasun
TO THANE
Hi Thane,
I come across your patent application 2602439 Toroid generator coil and in its last page where the Figures are usually placed it is written:
"Fig 1 and Fig 2: unscannable items received with this application"
Can I see those Figures please?
rgds,  Gyula
CRANKYpants
Quote from: gyulasun on October 08, 2011, 05:58:41 PM
TO THANE
Hi Thane,
rgds,  Gyula
DEAR GYULA,
THAT'S FUNNY THEY DID THE SAME THING WITH MY "INFINITY GENERATOR" PROVISIONAL PATENT.
TO TELL YOU THE TRUTH I FORGOT ABOUT THAT APPLICATION.
LET ME ROOT AROUND IN MY FILES TO SEE IF I CAN FIND THE ACTUAL FILING DIAGRAMS AND I WILL POST IT ASAP.
WHAT ARE YOU LOOKING FOR SPECIFICALLY?
ALSO CAN YOU POST THE LINK?
CHEERS
T
ramset
Thanks Grandma
CRANKYpants
Quote from: Overunityguide on October 08, 2011, 04:46:19 PM
So indeed this can be way to high for my 950Hz which I am Applying...
But unfortunately, 950 Hz is the upper Limit of my Frequency Drive Controller. So for higher frequencies we do need to get our own H Bridge / microcontroller circuitry. So gotoluc is on the right way by now.
With Kind Regards, Overunityguide
I WILL REQUEST (AGAIN) THAT YOU USE YOUR GENERATOR OUTPUT AS THE INPUT TO YOUR MOT   :P... YOUR INDUCTION MOTOR IS OPERATING AT 950 HZ BUT YOUR GENERATOR MUST BE AT ABOUT 2700 HZ OR SO.
I JUST THINK THIS WOULD A COOL VIDEO  8)...
CHEERS
T
CRANKYpants
Quote from: Overunityguide on October 08, 2011, 11:13:56 AM
Hello Guys,
As I had promised, today I should supply you with my input / output cop measurements regarding my MOT 950 Hz Experiment... (I will advice you, hold on to your seat...)
At the end this will give us a (theoretical) cop of: 0.327/0.018 = 18
But I have to say, for now it only works on small loads...
And further I have to mention, that of course in the MOT experiment my frequency drive controller is consuming a whopping 17.5 Watts only to run Idle.
DEAR OUG,
THE EFFICIENCY OF A TRANSFORMER IS CALCULATED BY THE OUTPUT POWER TO A LOAD DIVIDED BY THE INPUT TO THE TRANSFORMER PRIMARY.
THAT IS IT...!  :D
THE FREQUENCY OF A CONVENTIONAL ELECTRIC VEHICLE GENERATOR CAN EASILY BE 950 HZ OR EVEN HIGHER SO YOUR SIMPLE PROCESS MAY WORK VERY WELL AND ONCE CONVERTED TO DC THE FREQUENCY IS A NON ISSUE.
CHEERS
T
