Confirming the Delayed Lenz Effect
Started by Overunityguide, August 30, 2011, 04:59:41 PM
gotoluc
THIS POST WAS EDITED
Here is a replacement scope shot with Vmean on the Math.
Math is set at 50 Volts division.
Amp meter on the 12.2VDC side of the inverter shows the inverter consumes 400ma idle (nothing connected on output)
Under load it goes up to 1,130ma
The Series Capacitor used in this test is 15uF, Shunt is 1 Ohms, Secondary has a 10 Ohm Load Resistor with 6.52vac across it.
Luc
gotoluc
I deleted this post since the Scope shot Math was an error
Luc
SchubertReijiMaigo
According to your curve all the power is active here  :o :o  :o
Look like also the power is reflected since the input (on DC side) is increasing, finally look like this experiment is failed.  :'(
gotoluc
What do you guys think the peaks on the top of the Shunt Sine Wave are???
Luc
CRANKYpants
Quote from: gotoluc on October 28, 2011, 02:28:53 PM
If so what do you think the peaks are on the top of the waves ???
Luc
THEY ARE FREE AND HAPPY HUMPBACK WHALES... NOT RELATED BUT REALLY WORTH WATCHING!  8)
http://www.wimp.com/humpbackwhale/
CHEERS
T
