Confirming the Delayed Lenz Effect
Started by Overunityguide, August 30, 2011, 04:59:41 PM
CRANKYpants
Quote from: gotoluc on October 28, 2011, 12:34:19 PM
THIS POST WAS EDITED
I added an Amp meter on the DC side of the inverter and it idles at 400ma (nothing connected on output) and under load it's at 1,130ma - 10 Ohm Load Resistor with 6.52vac across it and the Shunt is 1 Ohms.
Luc
OK - THE OUTPUT IS 4.25 WATTS... WHAT IS THE DC INPUT VOLTAGE MR. MASTERBOATER?
12 VOLTS?
CHEERS
T
gotoluc
Quote from: SchubertReijiMaigo on October 28, 2011, 03:29:32 PM
Harmonics distortion (maybe due to resonance and saturation of the core)
It's not Saturation!... this is a 300VA Toroid. It will not Saturate at this low of a Current input.
Please note that this only happens when using the Sine Wave Inverter and not when Connected to the Grid.
Luc
nul-points
Quote from: nul-points on October 28, 2011, 06:06:34 PM
hi Luc
i've seen something like this recently - will check
thanks
np
yeah, this is what i remembered seeing - a YT video by user 'selfonlypath' showing results obtained with his 'Transverter' setup (2x MWO trafos modified & connected together, then driven with an 'H' bridge)
  http://www.youtube.com/user/selfonlypath    eg., see 'Transverter 1'
at a combination of resonance and with the i/p volts just passing thro' a threshold, the o/p sine wave 'snaps' into a more triangular waveform with elongated peaks
the snapshot below captures the moment when the o/p changes from a sine to a 'triangular' wave with peaks
of course, you may just dismiss people's contributions as 'being on drugs'   ...but you did ask for feedback   ;)
cheers
np
http://docsfreelunch.blogspot.com
gotoluc
Quote from: gyulasun on October 28, 2011, 04:34:23 PM
Hi Luc,
I still think the transformer core starts saturating (even though its primary AC current is just under 700 mA in your latest test when you had 22 Ohm shunt resistor in series with the primary coil).  The time-coincidence of the red scope waveform's spikey peaks with that of the green input current shows this I believe.
In the link below  you can see a scope shot on current shape through a saturating inductor (note: there is a misprint, D4 in the text below the schematic should read as D3).
Here is the link:
http://www.dos4ever.com/flyback/flyback.html#ind2
What output power is the sine wave inverter manufactured for, just curious, I do not think you overload it.
Gyula
Hi Gyula,
you may want to edit your post (if you still can) Please look at the Replacent scope shot above.
Regarding the peaks, it's not Saturation of the core. This is a 300VA Toroid, it takes much more current then that to Saturate it. Also, please note that these peaks only happen when connected to the sine wave Inverter. When connected to Grid there are no Peaks. See post with Grid scope shot on the next page
The Inverter is rated at 1000 Watts Continuous. Paid $300. for it
Thanks for your time
Luc
gotoluc
Quote from: CRANKYpants on October 28, 2011, 07:54:25 PM
12 VOLTS?
CHEERS
T
Yes, 12.3 Volts DC
Thanks
Luc
