Confirming the Delayed Lenz Effect
Started by Overunityguide, August 30, 2011, 04:59:41 PM
synchro1
JLN'S new Lenz Delay replication experiment starts with 18 N-S stator magnets at 600 Hz. 18 times 600 equals 10,500. The diametric magnet stator Lenz delay threshold speed of around 25k divided by two yields approxametly the same amount! Those are the pole shifts the coil makes per second. At that speed, the magnet stator simply begins moving a tiny bit faster then the coil's pole shift rate and gets a push, with or without an output coil.
http://jnaudin.free.fr/dlenz/DLE08en.htm
DeepCut
Quote from: synchro1 on March 01, 2013, 10:54:25 AM
Thanks for that synch, it's good to see Naudin taking this up :)
DC.
gyulasun
Hi synchro1,
Thanks for the pictures and the link to the energetic forum, I read through it again. Unfortunately you had camera problems and my questions remained unanswered and albeit later you made even some videos, actual measurements did not turn out and later the thread went down on the topic and abandoned...
Would you mind telling when you find the current goes to zero Amps, how much current is still flowing, really zero or there is a few milliAmpers flowing which needed to maintain the +15k rpm?  After the many tests you did in that era what is your present understanding on the phenomena:  any chance to go higher than 1 in COP?  Do you need technical help perhaps?
Regarding Naudin's tests you mention below,  he has showed detailed input power measurements which is very good indeed but miraculously this time he did not show the corresponding output voltage and current values... ( http://jnaudin.free.fr/dlenz/DLE10en.htm )
IT is ok that he confirms the regeneration effect but from his demo it is not clear whether there is any benefit from it COP wise? Afterall, this is what we are interested in, are we not?
rgds,  Gyula
synchro1
@Gyulasum,
I tried to self loop the gizmo and blew up a cap. I discovered that a seperate bifilar series wrapped pick up coil with two coupled diametric magnets back to back in the air core of a plastic Radio Shack magnet wire spool with a 1/2" core did the trick. This magnet core output coil caused the 3/8" magnet rotor to speed up while held errect over the axled spinner. Self looped, it charged the run battery vigorously. Definitly way O.U. I've been over this lots on the Romero thread, but I know of no one who has as yet replicated the results. The Lenz delay effect threshold drops dramaticly with coupled diametric magnets snug in the output coil core. Don't forget to tape the holes closed or they'll wind up stuck to the stator magnet.
                                    "THE OUTPUT COIL POLE SHIFTS HAVE TO FIGHT THE POWERFUL CORE FIELD."
Floor
Yes so collection of back EMF will be absolutely necessary ?
