Confirming the Delayed Lenz Effect
Started by Overunityguide, August 30, 2011, 04:59:41 PM
gyulasun
And they have the Internal split field generator as well:
http://www.google.com/patents/US8089188
Gyula
synchro1
Quote from: gyulasun on March 02, 2013, 10:25:36 AM
Gyula
I see your points. That's what caused me to replicate Leon Dragone's solid state generator. I made videos of it. Dragone patented the Magnet pump Generator. Two disk magnets on each end of a core winding. The field oscillation inside the magnet core output coil accounts for a good share of the abundant amperage. All the time, the slowed pole shift from very powerful magnet core field interference, motors the prime mover like a pulse coil. The power agitated by the spinner hepls drive the rotor magnet with greater force. Three great advantages in one!
garrypm
Are not, both those patents, very close, if not, a direct description on Willis' comments on dragons den of his magnacoaster !!!!!
Garry
synchro1
I built a Cook battery. I filled 8" of electrical conduit with 8 1/2" diamectric tube magnets and wraped it with first 1 layer of 32 gauge magnet wire, then one layer of household 16 gauge. This bifilar was then series wired Tesla style.. A capacitor and Schottky diode were wired in series. A spontaneous charge built in the capacitor untill it reached a ceiling level.
I held the cook battery up to a large rotating 3/4" diametric neo tube spinner, to see how the cap charged, and Lo and behold! The spinner took off like crazy and peaked the cap charge. I then simply scaled the Cook battery down to the 28 guage 2 magnet core design That went O.U.
I want to stress that theory followed results, not vica versa. As of now I can explain the effect in simple terms we have grown familiar with through the course of our intrest in the "Thane Hien's" effect. I think nearly all of us are prepared to fully understand what this is in Mandrian:
"Diametric magnet core bifilar output coil, PM field induced Lenz delay pole shift interferance lag retro-pulse propulsion" as a principle of electromagnetic physics both here and at home in China..
synchro1
How's this one?
             "Linear Tesla output coil Lenz poleshift retarding permanent diametric magnet core, retro pulse propulsion overunity."
At first I thought the magnet coil generated current. I ended up understanding how "Entropy" was doubling back to re-emerge in it's mirror image as a power mover..
Speeding the rotor up to 25k goes past the threshold, but any output is too hgh in voltage to self loop. Dampening the pole shift with diametric magnet cores, brings the rotor speed down enough to charge a 12 volt run battery off a rectifier. Measured around 20 volts. The strong magnet cores kill the coil efficency off by a good 95%.! The output coil needs a load to generate Lenz delay propulsion. The rotor winds down when the output hot lead is disconnected from the run battery as a load!
