Confirming the Delayed Lenz Effect
Started by Overunityguide, August 30, 2011, 04:59:41 PM
ALVARO_CS
Hi DreamThinkBuild
I think there should be no difference as for the current path is reffered, but I have a lot of steel laminations from an old trafo  I can use as core before trying the diam. magnet, so I can experiment with relationships between area facing rotor, coil area and  also volumes (masses related to flux densities & rpm, etc.)
In an intuitive way, I think that this physical aspects are related to harmony laws. The golden mean is just a tool (guide) to order things when I build.
Many times one has a wide range of aleatory choices and I always give preference to this proportions.
may be I´m nuts
cheers
DeepCut
Quote from: ALVARO_CS on March 20, 2013, 01:18:48 PM
Hi DreamThinkBuild
may be I´m nuts
cheers
Random choices can lead to amazing outcomes :)
If the golden mean is good enough for artists and architects then it's good enough for us.
atb,
DC.
hartiberlin
Hi Thane,
in your PDF file you wrote:
The DC power supply input to the BIONYX motor was
set at 20 Volts and 3.91 Amps or 78.2 Watts.
Bike Input Power = 78.2 Watts
ReGenX Output Power = 84 Watts**
** The bike motor input was 78.2 Watts and the
ReGenX power delivered to the purely resistive light
bulb loads was 84 Watts. This output power number
was actually higher than that because I had to use a
step down transformer for the generator coils which
consumed about 15% of the generator output power -
so the actual output was about 100 Watts or so.
So why didn´t you just film this and have it as a proof for us all to see ?
Didn´t you have a camera with you or couldn´t you just use your cell phone to
record this most important OU event ?
Hope you can soon show it again.
Regards, Stefan.
synchro1
Newton II
Quote from: THANE HEINS on March 20, 2013, 08:10:38 AM
THE 24 COILS ON THE INFINITE RANGE eBIKE PROJECT WILL DELIVER A MINIMUM OF 384 WATTS OR 16 WATTS/COIL.   THE BIKE MOTOR WILL CONSUME A MAXIMUM OF 360 WATTS.
ts
ONCE COMPLETE THE INFINITE RANGE eBIKE WILL RUN "FOREVER" AS PLANNED JUST AS WE DID AT OU (OTTAWA U WITH THE BYONX eBIKE).
I don't understnd the logic in the above statement.   Input power to the motor is 360 watts.  Total output is 384 watts @ 16 watts/coil.   Which means from the out put of 384 Watts if you feed 360 watts back to the motor, you will be left with just 24 watts of useful power output to run your bike.   Will your bike run with just 24 Watts?
Is it a toy bike?
As for I know a 100CC bike produces a power output of 7 to 8 BHP which is around 5 to 6 Kilo Watts to pull two persons sitting on it.
With 24 watts output you can make a toy bike to pull a rat sitting on it.   Am I right?
