Confirming the Delayed Lenz Effect
Started by Overunityguide, August 30, 2011, 04:59:41 PM
conradelektro
Quote from: DeepCut on March 23, 2013, 08:24:21 AM
I use your option 3 in that setup.
It's the basic inductor circuit used by Adams then Bedini, the sensor or trigger wire is on the same coil-former as the driving/pulsing wire.
Mine isn't particularly efficient, using 7-8 watts to drive that very light, single-magnet rotor, but the rotor can get up to 40,000 RPM depending on the choice of resistor and has generated in excess of 1 kilovolt at 3 or 4 mA in an inductor made of two pounds of wire.
All the best, DC.
In option 3 I forgot to mention the Adams or Bedini circuit, which was of course the starting point for the circuit I showed.
I like a separate trigger coil (in contrast to winding the trigger coil onto a drive coil) because the separate trigger coil can be placed at a sweet spot. One can place it at a certain distance from the passing magnet(s) and also slightly offset from the theoretically demanded position to influence the moment it triggers the transistor (driving the drive coil or coils).
I have seen ball magnets driven by the Bedini circuit (or a close variant of it), but I wonder why it works. Only one magnet pole should trigger the drive coil in the correct way. What happens when the other magnet pole passes the trigger/drive coil is a riddle to me?
I attach a drawing depicting the "drive problem" when using a Bedini style drive circuit and N S N S facing magnets on a rotor.
But as I said, it seems to work with a single ball magnet and a single diametrically magnetised ring or tube magnet. But I doubt a Bedini style circuit will work with a rotor having magnets along its circumference with alternating poles N S N S.
I will make some tests, but it has to wait a few weeks.
Greetings, Conrad
DeepCut
Yes, i'm familiar with the problem.
When i use an inductive drive coil on a N/S rotor it works but only at just over half the speed of the same rotor with the magnets turned N/N.
I'm also surprised there is any rotation, perhaps the flywheel effect is to account for it, the mass/velocity of the rotor overcomes the opposing pole ?
All the best,
DC.
gotoluc
Hi synchro1, DeepCut and everyone,
Looks like much activity ::) has been going on here.
I was away for a few days driving from Florida back to Canada.
I just now ordered 2 Diametric cylinder Neo magnets: http://www.ebay.com/itm/120743166252?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1439.l2649  to confirm synchro1's findings. However, now that I'm in Canada the delivery will take some time since the magnets come from the US. If I was still there, I would of received them in 2 to 3 days.
Looking forward to testing synchro1's findings
Thank you for sharing
Luc
DeepCut
Hi Luc, must be nice to be home again :)
My acrylic tube has arrived so i will be testing a magnet as a core as well.
Sync says that the generator magnet must be spun up to full speed in order to negate it's attraction to the core magnet, i do this using a typical Adams/Bedini drive coil.
With a very light shaft (carbon fibre) and miniature, flanged bearings, my magnet spins at up to 40,000RPM with an input of around 7-8 watts.
Looking forward to sharing results/observations,
DC.
DeepCut
Photo of the two magnets :
http://s1274.photobucket.com/user/deepcut71/media/DSC02949_zps3fd92aeb.jpg.html
e2a : the bright light on the lower magnet is the laser tach reflective paper.
Cheers,
DC.
