Confirming the Delayed Lenz Effect
Started by Overunityguide, August 30, 2011, 04:59:41 PM
synchro1
@crazycut06,
I didn't realize I could light the 120 volt ac LED directly off the output wires. I would have kept the 1/2 inch ball in the PVC coupling running because the sphere was levitating. steady and silent. 80 Lumans has a candle like warmpth.
The feedback power amplification texhnique was used by Pirate Twinbeard. That's how he reached those mach 3 speeds. The dual nature of the pancakes, one as power, the other as inductor allows us to add one to the other The power would be multiplyied thousands of times at mach 3. Any tiny discrepecy in COP is overshadowed when we close the Feedback Power Loop from the side pancakes.
DeepCut
I can't get synchro's setup to work.
I'm thinking perhaps it's because the magnets i am using are more powerful than synchro's.
My magnets are 0.6 Tesla.
I spun up the rotor magnet to 32,000 RPM (i think my bearing plate is a bit tight so not getting 40KRPM) before approaching it with the coil with the magnet as a core.
The attraction between two 0.6 Tesla magnets is very strong, perhaps this is the reason it's not working for me.
Perhaps Luc or Hoptoad will have better luck with weaker magnets.
All the best,
DC.
synchro1
I described "two"  diametric magnets coupled end to end, not one. They pull the field away from the ends when they're cojoined.
gotoluc
Quote from: synchro1 on March 24, 2013, 04:05:37 PM
My diametric magnet core ran the full length of the solinoid coil from end to end. I had up to 8 magnets end to end in my Cook Battery. The coil should not be longer then the magnet core. Working with only one 1" magnet, the coil should not exceed 1" in length.
Thank you sync for confirming that
Luc
