Confirming the Delayed Lenz Effect
Started by Overunityguide, August 30, 2011, 04:59:41 PM
twinbeard
I have not as of yet, but I find it interesting.  Thank you.
Quote from: Here2njoy on March 28, 2013, 12:53:09 PM
Twin
Do you follow this guy on youtube?
Suspicious0bservers
synchro1
@Twinbeard and DeepCut,
Look at this one I'm having fun with charge rocking. Believe me I can do this all day, harvesting "Lenz Delay Propulsion": Enough to keep it even minus losses. The neo sphere's running LENZ FREE at Lenz Delay threshold  r.p.m. , while delivering the same baseline voltage of 11:37 volts to it's own power battery. I submit these video results as bona fide confirmation of "Lenz Delay Effect". This unit is OU the amount of power it takes to illuminate a 120 volt LED to 80 lumens from the primary power coil bemf Bedini charge. This is no gimmick!
http://www.youtube.com/watch?v=nEtnFn6TAzs
The last run is over a period of hours, from 11:34 volts to 11:35 volts.
skycollection
Yes...you're wrong, the power supplay is for the trhee starships only, and all the inductors (tesla pancakes) are "PICKUP COILS" they are not connected to the power supplay....! i have an inductor inside of each strarship coil and others individualy inductors, IS THE MAGNETIC INDUCTION that makes the work...!
saludos jorge
synchro1
@Skycollection,
@Bienvenidos Companero,
              Muchas gracias para todos. Todos vosotros gustamos mucho sus produciones estupendos!
Perhaps field intererference is inducing reverse Lenz effect? Place a good amp meter accross the input lead, and check for any rise in amp draw when you add the individual pancake pickup coil and LED! The rise in input should match the output. A lesser amount will allow is to calculate the exact percentage of "Lenz efficiency" for the coil.
