Farmhand
Conrad, Have you tried using a charging circuit in your arrangements ?
Like the setup Tesla shows in the "Electrical Igniter for Gas Engines" patent http://www.google.com/patents?id=iAVhAAAAEBAJ&pg=PA1&source=gbs_selected_pages&cad=1#v=onepage&q&f=false
They see use in Tesla coil primary circuits ect.
I put one on the input to my motor and got good results from it, the drawing shows my exact setup, and the scope shots show the results.
I was able to get up to almost 19 volts in the 200 uF supply cap to discharge through the motor coil.
It seems that cap gets fully discharged and recharged to 19 in fairly quick time.
Anyway I get better performance with less input power and the drive coil gets a capacitive discharge from 18 or so volts, more bang ! .
As the frequency gets higher the voltage also rises in the supply discharge cap.
The charging inductor can also restrict current because of it's inductance and it exerts a force with it's core as well but if that can be used while retaining the effect is another question.  ;)
Cheers
P.S. Maybe a wave form from the charging inductor itself might be interesting, i'll get one.  :)
Edit: Inductor current is taken across a 0.1 ohm resistor between the supply and the inductor, the inductor voltage was probed between the diode and the inductor.
DeepCut
@skycollection
You are being criticised because you act unfairly.
We all know that without the advice of GotoLuc you would never have made those coils.
We all know that Luc got his info from Thane Heins.
Credit where credit is due.
If you behave fairly toward others, they will behave fairly toward you.
Quote from: skycollection on April 26, 2013, 07:47:56 PM
Conrad, you mentioned capitalism in my work and i think is a mistake becuase i have a good work in my country, and i donĀ“t need wire, resin, magnets because i can buy them, the important to share information not means that i have the "obligation" to share with other countries that are attacking me with bad commentaries. I AM NOT USSING PATENTED DEVICES, FOR EXAMPLE THE BIFILAR PANCAKE TESLA COIL, I AM USING MY OWN CONFIGURATION OF PANCKE COIL.
In other works, i would like to share information if the CONDITIONS ARE SAFE AND GOOD, not attacking with bad videos like ZEROFOSIL that delete HIS BAD VIDEO, this is the kind of people that want to share information "ATTAKING" WITH BAD INTENTION..?
SALUDOS
JORGE
Quote from: hoptoad on April 26, 2013, 07:29:48 PM
Will you explain what controversial behaviour it exhibits?
Cheers
This motor is a multi-turn analogue of the "Warlock's Wheel" aka Siberian Coilu of Stefan Marinov. If you are familiar with Jeffrey Kooistra's work at Mallove's Infinite Energy Magazine laboratory, with his version of the Warlock's Wheel, you'll begin to see the possibilities.
gyulasun
Hi Conrad,
Very good tests, they show the importance of AmperTurns by using drive coils with very high number of turns. Of course this increases AC impedance but it seems the tradeoff is still on the positive side when comparing rpm and power draw with lower impedance coils.
Yes the drive circuit shown by DadHAv is interesting, I have not seen it, it is worth testing.
I will be away for some days and return about May 2.
Keep up the good work.
Greetings,
Gyula
Quote from: conradelektro on April 26, 2013, 03:46:35 PM
I now have a comparison between the black and the white coils used in Version 2 of my ring magnet spinner. One sees from the measurements that the black coils have about double efficiency in comparison with the white coils (see attached picture).
hoptoad
Quote from: TinselKoala on April 27, 2013, 08:39:18 AM
Thanks for the reply, although I'm not familiar with the work described or the people you've named above. I'll have to do some research.
Cheers
