Ibpointless2 Crystal Cells
jbignes5
I like how John finally went to an expert and found his answers. The problem being is that the experts don't explain the other processes going on there. They seem to forget the mass and surface area matter has. They fail to explain the complex flows of planes and surfaces provide. Some are like coaral and are very porous and some are very very smooth. All the while a strange event also plays out. INDUCTION. Resonance. and surface tensions... They don't include the realms they deem unfathomable. They only provide one side of the story.
triffid
I conducted some real experiments today.I got a brand new sponge,put it into a dish to hold it firm .poured water from the tap onto it to wet it down good and stucked electrodes into it and took volt readings.What I had done before that was to heat up two copperplated nails until they turned black with copper oxide.I stuck these into the sponge as well plus a steel safety pin.I also had one copper plated nail that was never heated.So three nails one mag strip and one steel safety pin stuck in a wet sponge.
voltages between the nails only ranged from ..011 volts to .050 volts.Put the magnesium in and it went to 1.18 volts and 1.22 volts using voltmeter probe for electrode and mag.So at this point I looked for some steel and found it in safety pins.
next:1.08 volts for mag and safety pin
         1.23 volts for black oxide nails and mag.
What I think this means is that I can get more voltage out of  black copper oxide electrodes than I can get out of copper electrodes alone
triffid
triffid
Yes black copper oxide is conductive!triffid
ibpointless2
Quote from: jbignes5 on March 11, 2012, 06:32:36 PM
The expert told John to go here http://www.chemistryland.com/CHM130FieldLab/Lab8/Lab8.html
On that website it talks only about galvanic reactions, even a potato battery is mention. It seems the expert is trying to tell John that his cells are galvanic.
@ All,
Here is where the chemistry professor told me to go and look.
Lab 8: Single Replacement Reactions
John B"
In the web page it says that magnesium dissolves. "
When it does, the magnesium should dissolve and copper ions should become particles of copper metal."
One thing i saw was interesting was that the magnesium in water will produce bubbles.
[font='times new roman']
[/font]
jbignes5
 I started looking back to what we can see at the smallest levels and I think this one is very interesting.
http://nanopatentsandinnovations.blogspot.com/2012/02/photonic-crystals-turing-heat-into.html
I think what they did was grow crystals from tungsten. They just masked the holes with a chemical which will repel the structure building solution. But this is done at very high temperatures. And special masking techniques have to be used. I highly doubt we normal guys could do this.
My thought is that we are doing the same thing here but at a lower room temperature. The formation times get extended with a lowering of temperature but none the less should be similar. Our method utilizes the matters orientation and how it automatically builds to those complex interactions on the fly. crystals are strange. They are a growing product. They evolve and change based on discrete environments of available material and propagation of that material in the ever changing landscape.
The strangest thing is we can use seeds to start the process and generate better bases to grow from. Specially grown crystals could be harvested to provide a better matrix to grow from and provide a stronger capability to push or transform pushes into usable energy. These matrixes could be in paste form till they are needed. Once installed into the unit the unit should be polarized then vibrated to allow the past matrix to align to the natural voltages of the plates of the device.
Now from what I hear most toothpaste has ultrafine sand in it. This sand might be a key aspect to our paste. Quartz definitely should be tried with this. Salts would be self forming after a phase change from molten to crystalline form so salts should have no issue with alignment. But salts carry their own bag of tricks and I think we have figured out a few tricks of our own that helps the crystals go in the direction we chose without harming our electrodes. The only problem then is maintaining the current abilities of the cell. Weather that be sealed as much as possible or practicability remains to be seen. There are two splits now from this one idea. One utilizes water as the vehicle of energy. That gives some momentum having water tied to the charge being carried. The other utilized the structure itself to focus and impart a gain in potential between the two. You could think of it as a lens that is magnifying the intensity of that spot. Just as in nature you can harness the power of the sun likewise you can do the same to this energy via a suitable focal lens. You could think of it as the perfect heat engine. And some are photaic as well. And some are vibrational detectors too.... We have many aspects we can harness all at the same time.
We have to stop looking at this from the traditinal accepted rule. The still teach electrostatics at the college level. We need to start understanding what electrostatics is really and the laws it follows.
OMG we have had the answer to cancer since 2007. WTF. Because it is soo cheap they don't want us to fix us. Got to love greed...
http://www.youtube.com/watch?v=jH0BJKC_LLw
