Ibpointless2 Crystal Cells
triffid
Thanks IB2 for the video link to john bedinis talk.I am impressed with his iron rod in a jar technique for extracting minerals from a rock.
I did something like put wood ash into HCL  and got all sorts of colors.I can explain his jar is tapping into the earths magnetic field.His rod is acting like a wire in a magnetic field(recall the north orientation of the rod)matches magnetic inclination of the earths magnetic field.The earths magnetic fields frequency varies so its catching some of that.Maybe pulsing at least 7.8 times a second.Then the cations and anions of the elements in the jar sort themselves out over time whether to attach to the iron rod or not.The talk was about transmutation of elements.I dont think that was explained too clearly in the first thirteen minutes.triffid
triffid
I have been impressed with iron.There is its ability to do ion exchange with silver ions in solution(water).Alchemy saw iron as important.The jar method I think comes straight from alchemy(the beginning of chemistry).People observed things and how they worked.Even if they didn't know how they worked.They remembered the details so they could reproduce them.Iron was important to magic I believe.To earlier religions even.
triffid
triffid
My six aspirin cells hooked up in series, they are over a month old now. Today they gave me 5.22 volts and .14 mAs  that comes to .78 milliwatts.
Most of the time they were not hooked up. I have not been draining them all this time.When they were new they gave me close to one mA.
PB the most I ever got was 1.89 mAs from a batch of new vitamin C cells.That quickly went down as it is the nature of these cells as the casimir plates move closer and closer to each other.When they finally touch there is no more voltage or amps.Giving them a touch of heat can recharge them,too much heat will burn them up.I am getting good voltage from the 6 aspirin cells however.  .87 volts each.Enough power to lite an LED.
triffid
Im wanting to use vineagar in my next batch of cells.Maybe do that this next week.I already tried one batch and the magnesium got ate up in no time.4 out of 6 cells died on me.I tried buttermilk next.No power boost from buttermilk(1.4 volts each) and vineagar had given me 1.67 volts each.I really need an eyedropper so I can control the amount of drops.Im using eyedrops now so first empty bottle will get the honor.I only want to put up to 5 drops in each cell with a good buffer.The first cells got a lidful each.Way too much.The vitamin C cells ate up two magnesium strips.Buttermilk and vineagar may be the way to go.
PB I have tried to make panels of 18 cells each.
But I seem to do better with 6 cells at a time.
I have used no electricity to prime the pump.I let the electrodes do that for me.
triffid
triffid
IB2 A pound of garlic contains four grams of germanium.I think the iron rod in a jar method might work at getting some of it out???
Just thinking out loud here,triffid
