Video On line, Proof Of Overunity With Permanent Magnets, LaFonte Research
Started by gammarayburst, November 29, 2011, 10:26:24 PM
gammarayburst
Quote from: Low-Q on December 04, 2011, 04:02:35 PM
I'm sorry, but I really can't see in which part the pendulum in the video is suppose to be over unity. None of the three videos shows this clear to me. What energy was used to position the pendulum in the first place?
Vidar
The pendulum has nothing to do with the system other than make the magnet assembly move with low friction.
The system operation has been explained countless times, it's so very, very, simple in it's operation. The video was not to show a self runner, but the first step toward a self runner.
Butch
See our Youtube site, LaFonte Research
gammarayburst
nightlife
 Here is a way that will help you.
Build two or more large curved sections of magnetic arrays. Wrap the each array with a coil of wire from the start to end at the 3/4 lenth of the array. Make sure a runner can enter and pass thru each one. Attach each coil to it's own cap. Then rap the last 1/4 of arrays with another coil. Now create a trigger and place it just before the end of each array. Attach to both the cap and end coil so that everytime the runner passes the trigger, it will dump the cap into the coil reversing the polarityof the field to repell the runner out. After that all is done you should end up with at least a propetual motion or maybe some extra. Make sure the arrays are placed far enough from each other to keep the magnetic feilds from touching. Then wrap all the arrays with a coil leaving a breaking point before the end of the coil reaches it's starting point. The attach the coil to either a cap or battery using diodes to keep the collected source from keeping the coil energized.
I shouldn't have to draw a picture but if I need to, just ask.
gammarayburst
The Horseshoe Magnet That Discovered The Fanner Effect The Wrong Way
I'm a horseshoe magnet and I like to gobble up steel he would always boast! One day while looking for steel he found a strange role of square steel plates in a long line. They lay there two plates side by side, then two more, then two more, they went on like that for a mile at least!
What a great dinner this was! He put the ends of his horse over the middle of the first two plates so he could chomp down on them and gobble them up! But to his suprise the two plates jumped apart! Well that didn't bother him because just ahead was two more plates and they were pulling on him so hard! They pulled him in and just as the ends of this hungry magnet got right over the middle of the two steel plates they seperated too! So he pulled to the next set of plates and the same thing happened! This kept going on over and over until he was going ever so fast and when he got to the end of the line of steel plates he flew off into the sky and was never seen again! Some people say he landed in Paris and is trying to eat the Eiffel tower!
By Butch and Mark
Low-Q
Ho-ho! That was a good story :)
The story do not tell if the metal plates separated enough to let the magnet attract to the next pair of metal plates. I hope the story is true, except the Eiffeltower part..
Maybe two set of bicycle chains in parallell would be useful for your experiment?
Vidar
