Thanks to ALL for your help!!
Any proof?
Started by firda, January 04, 2012, 01:04:22 PM
LibreEnergia
Quote from: one_christian_warrior on August 08, 2013, 02:22:58 PM
  You are using the massive geometric differences of pulley sizes to multiply your rotations = thereby multiplying your power.
It is really just that simple
This is some of the most egregious bullshit I've read on here in a while.
Power is not multiplied by adding 'rotations'. Torque may be multiplied (or reduced) but the rotational velocity is inversely affected.
Power, which is the product of torque * angular velocity is unchanged.
So I guess the best OU machine around must be a ten-speed bicycle. Thank God for the downhills!
Ah.... it's the overunity wheelchair design again.
Look, warrior.... get someone to help you make a video showing some evidence for your claims. Use a cellphone camera! Don't you have any friends at all?
A system that could have been taken directly from your drawing was "supposed" to be demonstrated Live on Camera on the Smart Scarecrow show this evening. Much touted, allegedly the inventor spent 2.5 million dollars over the past few years on it. But guess what... there will be no demonstration this evening, because the device doesn't work after all -- like every other device of this type, it is allergic to demonstrations that aren't completely controlled by the claimant.
Your claim is pretty much the basic motor-generator or MoGen scheme that every bright ten-year-old kid comes up with and tries to build with his first soldering iron and toy motors ripped out of model cars. It didn't work then and it doesn't work now, so if you want anyone to take  you seriously you will have to provide some evidence, not prayer, not pleas for money... .but evidence of your own that supports your claims.
elementSix
For having a device that produces radiant spikes, you sure don't seem to be a believer...  Your video with the HVDC Tesla Coil was awesome.  You had Pink and white sparks of radiant energy..  The thing you should try is current resonance.  I am pretty sure that if your setup doesn't consume amps, it will produce tons of radiant energy, Volts and Amps.  Your Tesla coil was almost there, you just need to adjust it a bit and you will get OU...  The proof is the Pink and white sparks you were getting off your coil..   Good Luck TK...
Proof is MagnaCoaster.  The only way he could get that device on the market was to make it output pulses DC...  It has to have some external input to run also.  But he does get a lot more out..
Pirate88179
Quote from: TinselKoala on August 08, 2013, 06:18:50 PM
TK:
Nice drawing but, you forgot the mosfets.  Also, you don't have near enough batteries in your circuit for a free energy device.
