Thanks to ALL for your help!!
Ghazanfar Ali Generator - Utlilizing trapped energy
Started by Ghazanfar_Ali, February 04, 2012, 03:14:30 AM
forest
madddann if you want to dicourage us then rather let it go, this is 2012 not 1990 !
fix you simulation , place mosfets exactly like Ali did
poynt99
@forest
Electrically, if the circuits are connected the same, it is irrelevant how the drawing appears, it will operate the same.
Same thing goes for inductors, the orientation has no effect, UNLESS you set up an initial condition for it, THEN it does. However, Ali has not made mention of an IC setting for the inductor, so the orientation does not matter in this case.
@maddann
Global settings can and will make a difference, so if you are simulating in MS, download Ali's files and start there.
.99
madddann
@forest
I just posted my findings, what is wrong with that? I really hope that in real life the circuit works like claimed by Ali.
@poynt99
I forgot to mention that if I do that, everithing miracolously works  8)
Dann
poynt99
Interesting  ???
My suggestion for you would be to take a screen capture of all the settings with the working files loaded, then compare these to the default settings.
.99
WilbyInebriated
Quote from: poynt99 on February 09, 2012, 09:02:35 PM
Interesting  ???
.99
poynt... would the global temp setting (if memory serves it's usually around 300K) being set to 0 or negative cause this?
