Ghazanfar Ali Generator - Utlilizing trapped energy
Started by Ghazanfar_Ali, February 04, 2012, 03:14:30 AM
Dave45
Using the homopolar configuration as the model, lets look at a normal transformer we have a primary wound cw and a secondary wound ccw so we are using only one side of the homopolar model.
We need to pull energy from both sides, I think Floyd Sweet taped the other pole as well as Leedskalnin.
Magluvin
Quote from: Tito L. Oracion on July 30, 2012, 10:39:21 PM
No! just do not connect the ends together but the end of the primary and the beginning of the secondary and serve as a waiter kicker converter and a;sdjhgioesytwierthkwertbdnf cv,msgfierrutiweytrqoeiur13-984549687543685545jttrjgkdfnglsdfgldjhgf;alkhgfdhgf;aoutireuteioutrpiutoitoqieutwoetokalkjdfds
dsflkasjflasjfasjflsjdf
dfgjrentre,mtndfhguryh,hgfjldgfnajgjafgn
I dont know what a waiter kicker converter is. Looked it up and dont see anything.
And, bdnf cv,msgfierrutiweytrqoeiur13-984549687543685545jttrjgkdfnglsdfgldjhgf;alkhgfdhgf;aoutireuteioutrpiutoitoqieutwoetokalkjdfds
Doesnt ring a bell either. ;]
MaGs
Tito L. Oracion
Sorry buddy but a little step more, then your there,
your really a good and brilliant person i know you can decipher it.  ;) [size=78%]  [/size]
forest
Ok Mags CASE CLOSED you opened Pandora Box
;D ;D ;D
What is the source of Lenz law ??? OF COURSE ELECTRONS, THEY ARE LEEDSCALNIN MAGNETS
We really have 4 forces in Faraday induction law that's why two situations are described.
2 fields : magnetic and electric free in space and two fields bounded to electrons inside wire, or two EM fields such polarized around conductor because of electrons inside.
Now what is really happening here ? We generate a changing in time magnetic field from electrons in primary, which produce electric field pushing electrons in secondary, they flip and show us ugly magnetic side which acts against electrons in primary pushing them in such direction which maintain balance of forces, the delay is what we use as a current will flow for a moment. Then power source give us more electrons on primary and next pulse is done.
However it will stop working if frequency is too high for a given material because electrons cannot flip so fast and move so fast (or rather pass the wave of current). I believe this is then DC current.
Roughly like that,
P.S. Mags - Tesla invented this as always  :P   DC current induction
Ghazanfar_Ali
As per Don Smith's Teaching:- the two coils side by side in CW and CCW fashion and with same number of turns once connected in such a way that say two ends of CW are 1 and 2 and those of CCW are 3 and 4. 2 and 3 are connected making a center tap and 1 and 4 are connected together. We can get maximum output between the two ends then which are 1-4 and 2-3. And this happens only and only when the coil is in resonance state. At rest of the freqs both the fields will cancel each other. Dave45 gave a very good hint to avoid these cancellation effects and the only solution is resonance through a caduceus coil. Caduceus coil has weird magnetic properties and the new field which is produced is scalar in nature often called Zem field. It has electrogravitic properties once pulsed in the range of micro-wavelength.
Here in schematic the Pri is supoosed to be fed through a train of pulses from 0v to +V. Duty cycle 50% and freq has to be the resonant freq found separately for LC pri and LC sec using a function generator and an Oscilloscope.
Kind Regards
Ghazanfar Ali
