Ghazanfar Ali Generator - Utlilizing trapped energy
Started by Ghazanfar_Ali, February 04, 2012, 03:14:30 AM
JJUK
ZIP FILES available at  http://tinyurl.com/7pzrv7p
If I've missed any then let me know and I'll upload them.
Ghazanfar_Ali
Quote from: forest on February 06, 2012, 11:04:43 AM
interesting  :o
@forest
So the ingenuity of my mind says if we are getting 149 VDC across the capacitor, why not to use a small amount of that voltage to run the 555 timer based pulse generator of the input stage. ;) That is why I said it can be turned into a 100 % self running generator. The key to start is the initial charge stored in the capacitor C2 or just touch 50V DC source to its electrodes for a while and then replace the DC source. That is how Tariel Kapanadze switches on its KapGen with just a 9V DC battery.
Best of Luck
Ghazanfar Ali
energia9
Quote from: Ghazanfar_Ali on February 06, 2012, 12:52:43 PM
@ Mannix and All other friends
Hello Friends
Here is the ORCAD and MULTISIM Files for my AliGen v 1.4
I felt that a small pumping of energy is required to keep the 4700 uF charged so why not to connect its one end to the pulse gen instead ground.
Now u can find it more easy to make the device run without any damping.
The load resistance I checked at 50 Ohms. And the simulation was still running. To be at safer side I chose 100 Ohms Load. I made it run for 60 seconds on Cadence ORCAD v 16.3 and it ran without damping. A lot of data from Simulation output.
By increasing Pulse amplitude u will get more energy. Therefore I increased pulse voltage. But it gives good result even with 5Vs.
Multisim showed me 62 Watts and ORCAD showed 14 W approx with an input of 10 mW.
Interesting isn't it?
I am not attaching ORCAD sim files as they are around 42 MB and only its schematic jpg .   Multisim files along with screen captures are as under.
I wish u all the best in your replications.
Kind Regards
Ghazanfar Ali
Ali, can this experiment be replicated with other transistors?   i have  Irf540n   n chanel mosfet -  33 A  100V
i really hope that what ur saying is true and you tried this in real life and works.
and what kind of core material do i have to use for the inductor?
thank you
Ghazanfar_Ali
@JJUK
Thanks Dear I got it from your given link.
God Bless U.
Ghazanfar_Ali
Quote from: energia9 on February 06, 2012, 01:45:53 PM
I havent tested IRF540n.
But I think if it can handle 1000 V at the start for 10 ms then there would be no problem. I just tested it on IRFP260. now I will switch to IRFP264 as it gives more power output.
Kind Regards
Ghazanfar Ali
