Hydro Gravity Roller
Started by vineet_kiran, March 10, 2012, 03:30:29 AM
diegra
Excellent Vineet.K ..
Do you have a video?
regards
AlanA
Hi Vineet_k,
thanks for your detailed description. Now I know what you mean. Very clevery idea :)
JEJEHO
Please note , we have to consider the weight of water in the cylinder. The arm of the weight at the top is higher than the arm at bottom , but at the same time the weight of water at the bottom side of the cylinder is higher than the weight of water at the top of the cylinder.
regards
Nixon
vineet_kiran
Quote from: JEJEHO on March 12, 2012, 07:56:26 AM
regards
Nixon
@JEJEHO,
You have got a very nice point.    I think that is the reason why it  doesnot  work as a wheel when mounted on center axis.   Even when this system is mounted on center axis,   the top arm will be more than the bottom arm but  still the system comes to equilibrium  at some point  for  the reason you have stated above.
Will the same thing come into picture when you use it as a roller?  ( I am not sure about it).    The top arm will be  of  far more lentgh  than the bottom arm with reference to the rolling axis  and  water being liquid  will slide  inside  the cylinder when cylinder  rolls.  Hence  you need not  lift  the weight  of  water as a whole.
Thanks  for  the nice catch.
Regards,
Vineet.K.
AlanA
@ Veneet_kiran
and now? have you discarded you idea?
