what is the easiet gravity wheel i can do i only need 2 kw
Started by theshiningeagle, March 22, 2012, 01:21:53 AM
theshiningeagle
im an architect and a researcher
im new here
what is the easiet gravity wheel i can start with
i only need 2 kw
A water wheel, powered by a running stream, hooked up to a DC generator.
theshiningeagle
i didnt understand u didnt give me any details ok no problem  thank u nice hint
...im talking about a gravity wheel which is easy to make or someone made an step by step tutorial for and can produce like 2 kw or something
excessAlex
In the site which sports the words "Free Energy for free independant people" you can find a slew of Newtonian will show you the nearest gas station where to buy your energy cheaper and environmentally friendly, with which you can power a generator with a combustion engine with pistons and connecting rods and an alternator with rotating brushes, which are the result of the latest research and most sophisticated technology available to us. .. and this is the ONLY WAY.
johnny874
Quote from: theshiningeagle on March 22, 2012, 01:21:53 AM
im new here
i only need 2 kw
  Eagle1,
What TK said is right. While it can't be gauranteed, the 4 weighted wheel might be the next simplest.
The basic idea is that the path a weight follows from top center to bottom center is longer than the path upwards.
The problem to over come is that the distance a weight advances radially on it's way down increases it's upwards travel.
The math can be done to show what might work. What is not understood is the time it takes for weights to shift relative to their upward and downward motion. This affects the amount of time a weight is in over balance and would be powering the wheel.
        Jim
edited to add; Eagle1, anymore, this is a skeptics forum.
