quentron.com
Started by Philip Hardcastle, April 04, 2012, 05:00:30 AM
0 Members and 81 Guests are viewing this topic.
lumen
I believe Quenco is already the most efficient by converting heat directly at 100% conversion.
Any other method that converts heat to electrical current using additional steps, can only function with additional loss.
Though if you think about it, if you have something that is always available and you lose some of it when getting it, does it really make any difference even if you lost half of it?
:D
trim12
I don't think even a fully developed Quenco will be a 100% efficient, there always going to be some small loses.  Asymmetry is the key to Quenco causing a very large inbalance of tunneling electrons between the emitter and receiver.
lumen
Quote from: trim12 on November 15, 2012, 07:21:14 AM
I am not sure how the loss or efficiency in the quenco can be calculated.
Using two different metals with different work functions causes a voltage difference at any temperature, so if an electron with a given level of kinetic energy can tunnel through the barrier between them, then it will lose some of it's kinetic energy. If the electron still contains enough kinetic energy it may be possible to tunnel back again, but now it requires more kinetic energy to go back because of the already existing potential difference.
Electrons with kinetic energy simply bounce around and transfer kinetic energy back and forth with other electrons in a scheme of adding and subtracting from other electrons. So if you have two electrons that do not have enough kinetic energy to tunnel through the barrier, then they might have an interaction that transfers all of one electrons kinetic energy to the other electron and now one electron can tunnel the barrier.
So in the end, it looks like over time, all the kinetic energy would eventually move all possible electrons across the barrier.
I am not sure if this is true, this is simply my understanding of what I believe is going on in the quenco chip.
We hope that Philip will give us a full understanding soon.
Qwert
Quote from: lancaIV on November 14, 2012, 03:03:02 PM
C.O.P.:  7x !
::) http://worldwide.espacenet.com/publicationDetails/biblio?DB=EPODOC&II=6&ND=3&adjacent=true&locale=en_EP&FT=D&date=19931012&CC=US&NR=5252176A&KC=A  8)
Sincerely
                 CdL
LancaIV, good find. Further reading:
http://www.freepatentsonline.com/CCL-310-300-p2.html
http://www.freepatentsonline.com/5252176.html
http://www.freepatentsonline.com/5252176.pdf
Abstract
This invention relates to a novel method of, and means for, directing energy through Si2 HSb2 in such a manner that normal energy parameters can be exceeded.
1. Process for preparing crystalline Si2 HSb2 comprising the following steps:
placing equal parts of Silicon and Antimony in a first mixture; ..........
Xeno
Hello everybody, and my best regards to you Philip.
I hope things are progressing accordingly, and like other wise men already have pointed out, that u got ure base covered when u go live whit ure invention, not only whould it be sad to see another brilliant, kind person looking out for mankind, 6 feet under, their invention stolen and hidden away, history has a tendancy to repeat it self when one challanges the corrupt dark powers in control of this planet. Especially when one upsets so many aspects of it at the same time.
How does one hope to change the way the system works, if one does not know how the system currently operates, fully and completly ?
I hope for the sake of mankind u know of the implications this type of technology have.
Just as the current systems owners have "safety" measuers and "intruder" alert warning signals, fail safes and so on to guard their il begotten stolen and self percievd power, wealth and property.
So must u have if youre main goal is for the whole of mankind to benefit from ure invention.
Patents, yeah once upon a time it served its purpouse, nowdays tho...
6000+ and counting, tc2800 saws, military application, 2 wolfs and a sheep vote whats for dinner, swimming whita group of great whites wearing nothing but a bloody meatsuit, if it looks like poo smells like poo taste like... need i add texture size densety and volume ? its resistance and displacment in water ?
Why would a bankrobber warn the bank hes gonna rob before he robs it ?
He doesent... thats just stupid.
They say there are 2 ways to change the system, either from whitin, or by not playing by its rules, forcing it to adept, preferable via problem reaction solution.
Either only works by outsmarting youre oponents.
Why do u think theyr trying to clamp down on the internet ? or why the president of usa have to power to shut it down ?
What have the internet brought to challange tptb ?
What say history about the main work force behind almoast everything that have been built, the heavy labor, still true to this day, altho in modern times somewhat disguised, via the economic system...
When the time is right, would reccomend doing a show and tell on ted.com share ure vision for the future whit quenco to millions of people :)
But before going public...
Record a full disclosure leaving nothing out, open source public domain, that goes on the internet inc u meet ure maker by the hands of those who would like nothing better then to supress this kind of technollogy for their own benefit, youre safety line aswell as mankinds. Ofc several bakups different places ppl u can trust etc, and none of you or ure companions can have nothing to lose, it will be used against them once its on their radar.
Any and all the dirty tricks in the book, treaths kidnapping murder etc, for them its buissnes as usual.
Hope for the best but always prepare for the worst.
Those who fail to prepare, are preparing to fail.
Thats my 2 cents, a lifetime of observation and some common sense.
Knowledge is power, over ureself, ignorance is power, that someone else have over u.
My best regards, wishes and good luck to u Philip
And may all of mankind benefit from quenco, putting and end to the energy wars, paving the way for world peace and tossing the corrupt monetary system in the trash where it belongs whit the rest of the psycopaths using and manipulating it for their endless thirst for power and profit, raping and plundering this planet...
Respectfully yours
/Xeno
