quentron.com
Started by Philip Hardcastle, April 04, 2012, 05:00:30 AM
0 Members and 18 Guests are viewing this topic.
Bruce_TPU
Quote from: sarkeizen on December 26, 2012, 02:32:44 PM
Total and utter lie.  You believe that what Philip describes is plausible.  You believe that Philip is capable of delivering said plausible idea.  I could probably list an easy half dozen beliefs you have other than "Oh only Philip believes"I'm patiently waiting for some people to realize that Philip has made this decision many times...and each time failed to produce a device. (28 times)
Where exactly is the innuendo?  Being a bad manager is absolutely correct - Philip himself has agreed with me.   Not to mention that it's a logical consequence of believing that Philip isn't a liar and that the Quenco device isn't the problem.  Again nobody elected you (or mrsean2k) to the high-and-mighty-council-of-what-is-and-is-not-a-waste-of-time.  Sorry you prefer that belief...why not just try and deal with the diversity that is life? Instead of badgering people into your belief system.   I'm perfectly cool with the fact that people here want to hide from some of the logical problems that come from Philip's repeated failures to produce a device.  (29 times)
  It's like watching a doomsday cult without the funny ending.It adds valuable information as to how seriously we should take Philips claims.   This is, as has been mentioned a few times simply a logical consequence.
How about you simply stop creating all the strife?  So far you seem to be a primary cause.  You know, with your vapid namecalling...just a thought.Well perhaps you should be having your little tantrum at Philip?  So far he has built nothing. (30 times)
Heck as far as this thread goes all you're doing is talking crap, vapid crap at that not even a logical argument and you sure don't appear to be building anything.  So perhaps you can yell at yourself in the mirror for awhile.What same thing am I saying?  (Gee I wonder!?  You are one stubborn, thick headed individual.  IMHO  30 times now you have repeated yourself.)
You keep leaving that out.When aren't you?  Take a nap, relax.
Case and point!
sarkeizen
Quote from: Bruce_TPU on December 26, 2012, 02:55:13 PM
Case and point!
ROTFL....so wait, wait, wait.  If you say something that implies that Philip hasn't yet selected a date to demo.  Nobody is allowed to point out that the truth is something different than that?   Ever think that perhaps you're coming up with arbitrary rules as a method of avoiding cognitive dissonance?
Similarly when you express your ire toward people because you like to pretend that they haven't built things while you defend someone else but again we're not allowed to point out the gaping hole in that reasoning?
Again don't you think you're kind of being arbitrary?  After all it's not like you're not repeating yourself....the main difference is that you're being vapid.  Uh congradulations?
lumen
Quote from: sarkeizen on December 26, 2012, 01:05:27 PM
Can you give me an example of a physical quantity exponentially increasing with respect to time without a unit?
Sure I can, how about your posts in this channel!
They seem to be increasing exponentially in time, without unit.
sarkeizen
Quote from: lumen on December 26, 2012, 03:53:56 PM
Isn't "posts per day" a unit?
lumen
Quote from: sarkeizen on December 26, 2012, 03:56:06 PM
Yes, posts per day could be a unit, so could words per day, so could bytes per day, bytes per hour, or minute or any way to quantize the data.
But then, I did not need any unit to see the result.
You only need a unit to prove to someone else a result! But that's not what you said.
Though, you could say I just believe that's the result if I don't produce any data to prove it, but the fact is, the data is real only you believe it is not!
