quentron.com
Started by Philip Hardcastle, April 04, 2012, 05:00:30 AM
0 Members and 18 Guests are viewing this topic.
Bruce_TPU
Hi Lumen,
Trying to talk to Sarkey is kinda like pissing in the wind.  All he does is pontificate and bloviate which is an obvious cover for a someone who lacked attention as a child.
Cheers,
Bruce
When they can't refute you, Sarkeizen, they attack you personally. It happens all the time -- trash the skeptics personally --  and the more severe the personal attacks against you, the more you know you are right on the mark. If they had real cogent arguments against your position they would present them. But they do not..... so all they can do to try to save face is to insult you, malign you, question your upbringing (insulting your family), threaten you, and so on, hoping you will give up in disgust and go away.
Keep up the good work.
fritz
I try to waste as little time in that OU Kindergarten as possible -
otherwise I appreciate people wasting serious amount of time to discover physics and the relativity part of electrodynamics beyond typical walls of engineering and traditional science.
But if somebody invests serious amount of time with the only theoretical approach of "can´t" work - it gets interesting.
Why does such brilliant minds waste their time with doubting somebody elses work ?
Why do such brilliant minds start to insult each other personally ?
In the end I prefer people doing something.
I think there are more productive ways for broken brilliant egos to get along.
Well, OU.com has seen better days to come. It´s up to you what you make out of it.
Making Kindergarten posts in a Kindergarten forum - is that your goal ?
Who cares.
Bruce_TPU
Quote from: TinselKoala on January 02, 2013, 05:56:40 PM
Ha!  This from the king of fraud and lies!  How IS that OCAL magnet motor working out, Al?
Truth be known, I'm sick of the whole lot of you, and what you all have turned this forum into.  Always trying to run off anyone who posts anything out of the ordinary.
And he (Sarkey) can't "give up" because he hasn't and won't BUILD anything!  Armchair trolls.  At least you build, even if you do lie about it working.  I know, it happened a long time ago.  Still, it just diminishes your credibility in HUGE PROPORTIONS.  Sorry!  Something about the boy that cried wolf and all.
You've made that accusation before, Bruce TPU, and just as before, you are unable to support your accusation with facts or references. You cannot, for instance, produce one single citation where the builder of the device you mention ever claimed that it was overunity in any way.
So you have proven my point, yet again. When you can't refute the arguments of skeptics, or understand what they are doing, you proceed to insult and make personal attacks without foundation or support, and the more you attack us the more we know that we are righteous in our skepticism.
