Thanks to ALL for your help!!
A new idea just came to me :: come on get inside
Started by theshiningeagle, April 05, 2012, 04:50:20 PM
Poit
Quote from: theshiningeagle on April 09, 2012, 08:37:04 AM
may be ur not updated
look at this
http://www.ebay.com/itm/GIANT-62mm-545-Watt-THERMOELECTRIC-PELTIER-COOLER-MOST-POWERFUL-TEC-on-EBAY-/310391676716?pt=LH_DefaultDomain_0&hash=item4844c91f2c
545 watt for only 43 dollars
the efficiency is the difference of temperature between the two sides
if u can make one side too hot and the other cool ....u successed
u can see also here
http://www.tegpower.com/
and ive explained up how to make it
and i dont think that no one tried my way even in youtube u can search as long as u can
but the new thing will be if u reverse engineer the hair dryer
u will tell me why while u have this chips
i will tell u .....that this chips needs temperature difference
but if u use the hair dryer u will not need the temperature difference
what im searching for now
is something realy hard to find
is there any kind of glass that totally isolate the heat means that one side is so hot and the other side is not hot
keep searching guys im sure of what im saying
I think you are confusing what the peltier modules max running wattage vs. the watts it could potentially produce (running it in reverse, i.e adding a heat source and cooling the other side)..
The 545 watts is the peak watts the unit will DRAW, not MAKE.......
it even states this on the ebay link you posted.. "Maximum power consumption 545 Watts"
Like someone already posted, the best your going to out put from any peltier module is around 5%
