Fernando`s Force multiplier
Started by neptune, May 03, 2012, 03:09:35 PM
gadgetmall
Quote from: neptune on May 06, 2012, 11:03:04 AM
Personally I would not waste my time and money on this. It is a sad reflection on modern education that no one seems to have asked for proof of input and output. Next year I will enter my invention of a personal levitation machine that will fly for months on the power of one AAA battery. It is bound to win a bronze medal, as no one will ask to see it actually working.{/quote]
Not if i beat you to it:) And know know Science says the cave men built Puma Punka .With Copper Chisels and stone hammers.
i_ron
Quote from: gadgetmall on September 01, 2012, 05:49:48 PMPersonally I would not waste my time and money on this. It is a sad reflection on modern education that no one seems to have asked for proof of input and output. Next year I will enter my invention of a personal levitation machine that will fly for months on the [/size][color=rgb(0, 0, 255) !important]power[/color][/size] of one AAA[/size][color=rgb(0, 0, 255) !important]battery[/color][/size]. It is bound to win a bronze medal, as no one will ask to see it actually working.[/size]
This is a work in progress, posted here for intelligent people to share and ponder.
Ron
gadgetmall
Hello i-rom that is a nice machine you got there . It reminds me of another build that used magnets to couple the rotors from the prime mover .
Thanks and good luck. If this works then it might be a great addition to my solar and wind power system using a grid tie.
BTW.. that was not my quote: :it was neptunes
i_ron
With permission from Arto, here are two JPG's which help to understand Fernando's multiplier:
Quote:
Here is a breakdown of what is really happening(refer diagram), as you can see the velocity increases and decreases as the 2nd wheel turns. [/size] snip The upward arm is an resonant device that allows the impulse force to be added to the 2nd wheel at the time when the velocity decreases thus maintaining an increase in the rotational momentum of the external flywheel. Adding more wheels will multiply this action many fold. This arm could be placed at different parts of the system, as long as it is functional as a resonator. snip Many thanks Regards Arto
Second jpg:
Here is another addition to the Sixto design, I would not build it as per my picture, it is the exaggeration of the offset that helps you see the real situation.
I hope that my efforts will help to make the Sixtos machine a everyday reality. I like UFOPolitics efforts in showing the asymmetrical nature of motor design, the combination of both types of asymmetry could make some very interesting engineering. I have been working on similar lines in one of my chapters from my book. If you look at the impulse in the time domain, it is a 1/4 wave system. In the distance domain it is a impulse wave. I will be working on the complete transformations and equivalence to the electrical equations in the near future. Thank you very much for your support, Regards Arto
Honza
Hi all,
I am new here. My regards to i_ron for his great work on the multiplier. I am playing already sometime with a concept on similar theme to that of  Fernado Sixto Ramos - so replication of his work is obviously of great importance to me.
I_ron, you've done great job in analyzing and building the unit. However, please do not underestimate the forces involved in the transfer of power from one wheel to another. The speed of both wheels fluctuates within constant % of their average speed. The speed fluctuation % is alternating between the wheels, it is proportional to the size of the crank (which has to be identical for both wheels) and it is inversely proportional to the distance between the wheels. The speed fluctuation % remains constant at any given speed. Therefore the energy transferred by the connecting arm (and the forces involved) are increasing exponentially to the average speed of rotation.
I_ron, after watching the video of your design I feel your connecting arm is the weakest point of your unit.
Also worth noting there is a Colombian inventor who produces units on similar theme. His name is Carlos Ucros and his design does much the same using different configuration only doing it slower and using greater masses.  His English is much worse than mine but the pictures on his site tell the story.            http://www.ucros-energy.es.tl/ENGLISH-.htm
He claims ~ 5 times power multiplication.
So from my contemplating of this revolving energy theme it appears that the multiplying factor will rise most with the speed. A design with higher speed, smaller masses, closer together, smaller crank, shorter and stronger arm and bearings is likely to deliver best performance, however also be technically most challenging and less durable.
Cheers
