Using Chas Cambel Flywheel System For 15 Horsepower
Started by thankGod, June 25, 2012, 11:57:43 PM
a.king21
To encourage you all: - Tesla did this with his earthquake machine, when he tested it on the New  York 10 storey skyscraper.
There are some rules: The input must be separated as much as possible from the output to avoid a feedback loop.
So a loose coupling is required. Even better if it mechanically connects and disconnects with every revolution.
Tesla never forgot this lesson and took it into the Colorado Springs experiments - with his resonant rise loosely coupled extra coil.
Please note:- Tesla's resonant rise is not today's definition.
wings
 ;) http://www.overunity.com/2487/chas-campbell-free-power-motor/msg94133/#msg94133
I  got curious  about this  thread and started reading I got  up to page 15  I take from this page that   everyone  has  written off the  flywheel  idea.The  skeptics  here  will say that they  are just  trying to keep people from  reinventing  the wheel .I think that chances are  that  the group here has UNinvented   the wheel   I  remember   many  years ago before I had any intrerest  in  saving   energy   there was a guy  on TV   with   a very simple  flywheel  based  machine  that he  said made   extra energy .       This  guy  explained   that  he had  built the  original    machine  with   spare parts   and  it worked very  well He then  built  a  better looking   version  . .........but the  new   version didn't  have any extra power.  He  said he  spent monthis  trying to figure out why the  original  machine  just thrown together   created extra power and the carefully  built  new machine   made no extra power at  all .    Then  one day  he  decided that  it was  time to change the  belt on the original   machine .     With a new  belt  tensioned  propperly  the original machine  no  longer  produced  any  extra energy . After playing  with the  tension  he got  the original  machine  to   start producing  extra energy again .   He loosened  the  fan  belt untill  it started   bouncing  a  little .   He  did the same with the  his new  version and it  started producing   extra power  too . He  he had the  camera zoom in and show  the  belt . ......it was clearly  not  running  smooth   it  was  it bounced  quit  a bit .......making the motor  pull hard then  idle      Pulses  of power was the secret  .   He  also  said that  he  found  it almost impossable  to get  engineer  types to  understand  this .   "they  always  insist on belts bing tight ."
tinman
Quote from: wings on January 17, 2014, 06:33:38 AM
Hi Wings
As you will see from my youtube chanel,i am all for finding the free energy machine-and have spent many years looking and building. But the answer is not in the Qmogen type machine's. This is just yet another of Stirling's rubbish machine's,that if the past is any thing to go on,he's hopeing to make a quid out of.
Now ,about this slipping belt thing-what dose a slipping belt cause?. It causes heat,and heat is yet another loss in a system where an electrical output is wanted.
There is one way to put this to bed once and for all-build one that runs itself,and we'll all believe. So far,not one person has done this,with the proof to back it up-not one.
tinman
Quote from: a.king21 on January 17, 2014, 01:48:44 AM
The earth quake machine was just a mechanical resonant oscillator. Works the same way as pushing a child on a swing-very little force required to move a large mass-when in resonance.
But here's the down fall= If an equal and opposite force is applied,the net result is zero.
http://www.youtube.com/watch?v=OKW03jo9RJQ
wings
Quote from: tinman on January 17, 2014, 09:20:21 AM
Hi Wings
long time ... also for me .... FE research is my spiritual path
the comments was not regarding slipping belt but regarding the speed oscillation due to the low transmission rigidity, as you can see the mass of inertia of this type of system is quite large one of the rules of FE is to not kill the source so the delay due to the rotational speed oscillation can be the solution.
