Simple to build isolation transformer that consumes less power than it gives out
Started by Jack Noskills, July 03, 2012, 08:01:10 AM
0 Members and 35 Guests are viewing this topic.
Hope
Quote from: T-1000 on August 12, 2012, 02:44:02 PM
Here is Romanov self runner in Russian side:
http://www.youtube.com/watch?v=7eKi7ol12c4#t=0h44m0s
The main working principle is in LC resonance in series generating pure current with lowest voltage in last winding as possible+ attached BEMF from Joule ringer for pure voltage and with much higher frequency sawtooth wave for mixing up with current. When current is mixed with BEMF voltage in 180 degrees to each other, it adds for summed up power.  Strangely enough, nobody was giving more attention to this...
Here is my quick drawn circuit and signals waveforms:
OM Gosh does anyone here have time to do a proper schematic translation from this information?    T-1000 can you provide us with a parts list as well?  We will look forward to an off the self parts project we can ALL make to the same standard world wide.
T-1000
Quote from: Hope on August 13, 2012, 05:55:19 PM
http://www.youtube.com/watch?v=S4swpF3k03c
http://www.youtube.com/watch?v=rZU1_i0kZ7M
http://www.youtube.com/watch?v=dlze-GnsxEs
http://www.youtube.com/watch?v=WCeQu18ck3E
http://www.youtube.com/watch?v=uObjlXTtgQY + http://www.youtube.com/watch?v=EVDNkF1npHs&feature=plcp + http://www.youtube.com/watch?v=66-DV9kY2dM + http://www.youtube.com/watch?v=slBPWQGBZwA + http://www.youtube.com/watch?v=7eKi7ol12c4
You need to understand the working principle first and do experiments for building blocks before you will be ready for complete setup...
dllabarre
T-1000
Is G1/G2 just a Joule Thief circuit?
How are 2 Joule Thief circuits wired together in your circuit?
Thanks
DonL
Jack Noskills
I suggest that we first get baseline replication of this simplest circuit as it needs just two coils, only then try mods to see if they improve.
I don't have equipment to make any videos, besides 30 watts free from the junk I use is not important as such, the operating principle is: output has no effect on input!
I would like to see what happens with iron core at higher frequency. Iron is no good when used as normal trafo at frequencies above 400 Hz or so, but this is not a normal trafo. Those two coils are in perfect sync with each other so their magnetic fields cancel. This means there is no magnetostriction as there is no delay, can this enable us to use higher frequency with iron ?
Before you say 'no', then think about Leedskalnin. He lifted rocks that weigh several tonnes and he said he used iron/steel cores. What if high frequency with iron creates anti gravity effect when coils are connected 'my way' ?
wattup, have you scoped what is the output waveform like, can you confirm if it is rectified sine wave ? If so, then at high frequency one could also say it is "DC with has component in it (SM)" or "dirty DC (TK)". Coincidence ?
dllbarre, I PM'd you the other day, don't know if you got it. Well, there was no information in it as such, just asked you to get back to me if you don't find the details you asked in TK thread.
