Simple to build isolation transformer that consumes less power than it gives out
Started by Jack Noskills, July 03, 2012, 08:01:10 AM
0 Members and 35 Guests are viewing this topic.
Jack Noskills
Quote from: iflewmyown on August 16, 2012, 01:59:10 PM
[size=78%]Quote from: iflewmyown on August 15, 2012, 04:08:57 PM[/size]
One result. transformer # 14T0011-002 surplus new.  Two multiple tap primaries N - 100v -105v -110v -115v -120v plus multiple secondaries. Idle current will reduce to 21ma. using 1.8 mfd 600v cap. 40w incandescent bulb on load pulls 40.8w on meter. Next test 40w bulb in input side glows brighter than one in load side. This transformer weighs 22 lbs. and was used to try to get a large measurable difference.
Garry
Jack :You need to use two similar coils from it and leave others unconnected.
That is what I did.
Jack: Use the finer coils. Measure the idle power of just one coil, then compare it to power you see when two coils are connected together (without load). Idle power should be lower. If it higher then second coil is wrong way and you need to swap connections.
That is what I did.
Jack: Check the efficiency of your trafo, use it as normal trafo and check how much power it can provide at output.
Each coil separate 124VAC .085A     Dc. ohms .8
Wired together .038A   no load
Normal isolation transformer  With load 124VAC 2.2A  input
Normal isolation transformer  With load 120VAC 2.2A out
Garry
I have been told that this setup halves the voltage at output, so if you have 120 volts coming in there is 60 volts at output. Output waveform is sinewave, also current is sinewave with some high frequency bumps in it, I counted four distinct bumps per one wave.
I think the parameters in your trafo are good enough, but not perfect. Idle power could be closer to zero with one coil, but still this should work properly. Since idle power decreases with two coils your wiring is correct.
Did you try the two lamp experiment ? Light on output side should be brighter than the current limiter bulb. If they are equal then something is not right. In this case can you provide a picture of your setup so connections and lamps are clearly visible ?
Can you do the two trafo experiment, also with bulbs ? First trafo need not be similar to first as long as it is 1:1, or 1:2 as voltage is halved at output.
Did you measure the resistance of the coils to make sure they are equal ?
Hope
Quote from: viny on August 16, 2012, 12:21:41 PM
@ T1000 (ARUNAS): Did you make a video of your setup?, unfortunately for me, I can't get it from your  quick drawn circuit.
                        Thanks
T-1000      I watched all those links in russian a few times    I understand no russian.   I see excited people and equipment and circuits.   I have a 1000Watt variac/ one constant voltage trafco 15 amps, one LARGE older neon sign DUAL trafco.   Can anyone make a finer detail schematic of the circuit for us?
iflewmyown
You asked to see my efficiency of my transformer
I replied
Normal isolation transformer  With load 124VAC 2.2A  input          Normal isolation transformer  With load 120VAC 2.2A out
It does halve the voltage wired as shown in the diagram.
I did try the two lamp experiment the input bulb is warmer, not the output. The DC ohms are listed above and are equal.
No one wants this to work more than me. I bought these transformers just for this experiment. I did the two transformer experiment with bulbs first. I listed the model number so no one else would waste money on this transformer. It may well work with every other transformer in the known universe but not with these two.
I was trained in this field forty years ago and it should not work like you claim so I didn't test your idea till just now. Every time someone sees something new to them they tell the world but I have only seen free energy three times in thirty years and I declined to pursue each of those ideas ( none were original with me )
I wasted an hour this morning retesting and twenty minutes typing this. ( I type very slowly ).
Garry
P.S. If you have this setup working with iron transformers at 60Hz. A picture with meters would encourage people. Even the two bulb test with an infrared thermometer would be helpful. I have been sucked in before by people with an idea who want someone else to do the work. There is free energy for the taking and it has to be somebodies idea. Once you have seen it you will chase every lead to make it practical.
Jack Noskills
Quote from: iflewmyown on August 17, 2012, 08:09:04 PM
I replied
Garry
OK, I just did not understand .8 ohms what it means, 800 ohms ?
Two lamp experiment when current limiting bulb is brighter than output tells me that load is possibly now in wrong place. It happened to me when the load was between the two coils. Load must be so that one end is connected to junction, that is in the middle where two coils connect, and the other end in the beginning of either coil.
Do you have a link for this trafo you are using ? It has iron core ?
I have one replication now by a qualified EE, low power trafo and coils have about 35 ohms resistance. This gave about COP of 1.5, a mere 7 watts extra but it is a start. Stronger coils would gave better COP. Output waveform is flattened sinusoid, so most likely meters are not quite accurate. Also voltage is divided by two. Bulbs are better determining difference in power at this level if there is no scope available. Maybe I can get pictures of these waveforms later once testing is complete.
Sorry this did not work for you, I would like figure out why if you still have strength to investigate more.
JouleSeeker
Quote from: Jack Noskills on August 18, 2012, 03:45:14 AM
[snip]
I have one replication now by a qualified EE, low power trafo and coils have about 35 ohms resistance. This gave about COP of 1.5, a mere 7 watts extra but it is a start. Stronger coils would gave better COP. Output waveform is flattened sinusoid, so most likely meters are not quite accurate. ...
Sounds great, Jack, but can you please tell us:
1.  How did he measure input power and output power?  2.  What are the actual measurement numbers he measured, for both input and output power?
3.   What circuit did he use, e.g., with or without capacitor?   actual circuit diagram please.
4.  And, if possible, can you tell us what trafos he used?  photo?
I would like to see this work also!  but more info is required for me to jump back in, since I'm one of those who did a replication (two actually, with different trafo-pairs) but only saw COP < 1.
Thanks, friend.
