My Invention
Started by johnny874, August 11, 2012, 10:59:31 AM
johnny874
 I will consider this post first publication as it will detail the invention and give the needed information for filing a patent.
My name is James Lindgaard and am the inventor.
Residence; Richmond, Ky.
The invention is a perpetual pendulum
On 3rd page.Provisional Application for Patent Filing Date Requirements It can be filed up to one year following the date of first sale, offer for sale, public use, or publication of the invention.
http://www.uspto.gov/web/offices/pac/ProvApp.pdf
Specification
The specification is a written description of the invention and of the manner and process of making and using the invention that concludes with the claims to the invention, which must begin on a new page. The specification must be in clear, full, concise, and exact terms to enable any person skilled in the art or science to which the invention pertains to make and use the same.
The machine operates because of an imbalance caused by a swinging weight. By having 2 weights suspended from a cross beam at different distance, when the weight that is furthest away swings inward and is caught by a hoisting mechanism, it's center of mass creates resistence closer to the pivot of the cross beam. By doing so, it allows the opposing suspended weight to have greater potential because it is suspended further from the pivot of the cross beam than the hoisting mechanism suspending the weight capable of swinging.
The hoist mechanism uses pulley's or pins that attach the catching mechanism to a ppoint further from the pivot of the cross beam but not beyond the point where the opposing weight is suspended.
The weight capable of swinging will be pulled free by a line attached to the base of the machine and to the weight itself or extension of the weight. This will happen when the weight is being lifted and the line attached to the base becomes taught.
When the weight is pulled free from the hoisting mechanism, it's force will act on the point where it's line is attached to the cross beam causing it to have greater force than the opposing weight.Title of Invention
The title of the invention (or an introductory portion stating the name, citizenship, residence of each applicant, and the title of the invention) should appear as the heading on the first page of the specification
  Perpetual Motion Machine
James Lindgaard , Citizenship is American
Background of the Invention
This section should include a statement of the field of endeavor to which the invention pertains. This section may also include a paraphrasing of the applicable U.S. patent classification definitions or the subject matter of the claimed invention.
Also, it should contain a description of information known to you, including references to specific documents, which are related to your invention. It should contain, if applicable, references to specific problems involved in the prior art (or state of technology) which your invention is drawn toward. See MPEP 608.01(c) for more information
The catch emchanism would ahve it's position maintained by having it's supporting lines be attached to the position on the cross beam from the opposing direction of it being used to hoist the swinging weight with. This would allow the catch mechanism to always be postioned to catch the swinging weight which is as important as any other aspect of this invention.
In previous attempts at perpetual motion, such devices have failed because they could not shift the balance of the weights without using the work gained from weights to reset the weights continuously. With this invention, it has solved in this instance the problem of  restting a weight so it can have a greater force than another weight maintaining a constant source of imbalance.
  Nice way of saving patent rights. And if successful, of course will have to remember the host.
Am not sure but may donate patent rights to charity. Building a working Bessler Wheel is what I would really like to see happen. With this in mind, if someone would like to work with me on this, let me know.
In reality, if I do this by myself, will keep the money. And in this day and age, electronic signatures are accepted. So if anyone helps me, some people would benefit from this and we'd get some recognition for it.
Something for you guys to think about. And yes, this is a legal contract if someone accepts the terms.
        James A. Lindgaard
johnny874
   @All,
  A cleaner drawing. The one I will build will use a deck with cleats. Somewhat of a homeage
to my having been around ships.
If the release line is attached to the top part of the catch mechnism, then when the line is pulled
taut, it should release the swinging weight. The weight can have the rod to the fulcrum going
through it. This will allow it to slide slightly up it as it pushes the catch mechanism away before
the catch mechanism moves under the swinging weight to catch it on it's return movement. it is this line which will
time the movement or rocking/tilting of the cross beam. The catch mechanism can catch pins that are located on the
sides of the weights. This means that there woulld be 2 catch mechanisms working together, one for each side of the
weight.
The cross beam's motion can be controlled by stops placed on the cross beam which interact with the
main support that the cross beam pivots on.
The pulley for the opposing weight can be attached to the main support at about an angle of 45 degrees.
This will allow the force the line places on the pin or pulley to be in the direction of the support.
The basic size from center pivot of the cross bem to the center of the pin for the swing weight is
12" (inches). The cross beam is centered length wise to maintain it's balance between left and right.
        Jim
And to modify the agreement I posted, I do not work with private builders associated with the Arrache build group.
This includes AB Hammer.
        James . Lindgaard
Well, you just blew any chance of patenting that scheme, if that was your intention, by publishing your claims and drawings publicly.
http://www.uspto.gov/web/offices/pac/mpep/documents/appxl_35_U_S_C_102.htm
You will have to complete and file a NONprovisional patent application within one year from today or you cannot patent it at all. And that's not even considering whether the patent will be granted.
You will also have to demonstrate that your invention is New, Useful, and hasn't been demonstrated before by someone else. Good luck.
Pirate88179
Quote from: TinselKoala on August 11, 2012, 03:36:13 PM
TK:
Exactly correct, from what I know.  I love the folks that post stuff on OU and then get help from smart guys like you....and then...remove all videos and posts saying they are going for the patent now.  A long time ago a very expensive patent attorney assured me it does not work that way.
johnny874
   @TK & Bill,
  How many private messages did you send each other before posting ¿?
I mean really, TK said I lost all rights for patent purposes and then Bill says watch me delete my posts which only a forum moderator like himself can do.
Still, for someone who is interested, let me know.
