Laugh at me or join me. My Magnetic motor that I spent 10 grand on
Started by catdog71, August 23, 2012, 12:05:46 AM
Cap-Z-ro
You might try aluminum strips...possibly combined with mu metal.
All the best.
Regards...
nightlife
I am sorry but you have to atract and store enough energy from movement to create a magnitic field large enough to cancel the field your trying to over come.The problem thus far is that no one has been able to do so because the energy needed to over come is greater then any energy collected from free movement created. Good luck to you and keep brainstorming, you may just be the one to make it work.
Cap-Z-ro
Hmmm, seems I've read some theory that gravity was an effect instead of a field.
It appeared to make sense at the time...and I would have to say I am leaning in that direction.
We would need more opinions on that issue to cause me to consider altering my evolving perception of things.
So the way I look at it in the present case is that over unity is still on the court.
Regards...
TechStuf
I checked out the J33:3 motor....nice scriptural quote btw.  So true.  TK said something that was 'bound' to catch my attention:
"The Jesus thing is a bit heavy, though. What, free energy is only for Christians?"
I daresay, heavy indeed!  Much heavier than the prospect of free energy under the current pseudo world regime.
Got a small tip for you 'Sermonplace'.  Disconnect the vertical axle wheel from the horizontal axle wheel.  Remove it entirely.  Make sure the horizontal wheel is allowed to spin freely.  Grab the following from Amazon or ebay:
http://www.amazon.com/Digital-Laser-Photo-Tachometer-Meter/dp/B005WLF7BE
Get a small plastic container like a film canister or a plastic egg and insert a watch battery sized NdFeB magnet, close canister and wrap with fine gauge enameled induction wire and connect each end to an LED diode.  Spin the wheel up to a reasonable speed by hand, measure RPMs and place the Neo/led assembly over the rim of the wheel above the magnets, you will find the sweet spot after a few tries.  Measure the exact time and RPM reading from the moment you place the Neo/LED assembly over the magnets to the time the wheel stops spinning.  Now measure the time it takes the wheel to stop spinning by itself without the assembly placed at the correct distance of the wheel.  After just a handful of tries, something important should quickly become obvious to you....and after a time, ideas may permeate your thinking on how to improve things.
Blessings in Christ
“For the wisdom of this world is foolishness before God. For it is written, “He is THE ONE WHO CATCHES THE WISE IN THEIR CRAFTINESS” - 1 Corinthians 3:19
http://www.freemasonrywatch.org/sixpointedstar.html
http://www.youtube.com/watch?v=XBjOs-egFMs
http://www.youtube.com/watch?v=_WSGwnz7XpY
http://www.youtube.com/watch?v=l39XsMcyvgA
http://portland.indymedia.org/en/2004/09/297062.shtml
http://www.youtube.com/watch?v=JjjIy1DO0gs
We all have the choice to waste ourselves in rebellion or to gain wisdom.  Therefore, gain wisdom:
http://www.hisremnant.org/eby/articles/kingdom/twohands/twohandsof.html
Magregus
Think about your magnets as well and the fields they are creating.
