FDM - flux displacer motor by Igor Knitel (Perihelion Labs)
Started by wizkycho, August 27, 2012, 04:36:27 PM
wizkycho
Hi all !
I have tried to order an ring magnet from china and magnet is not as expensive
but shipping cost a fortune.
where to order with lowest shipping price ?
@lumen
Where have you seen such "LenzAddingEnergyToOutput" setup, any links to experiment
lumen
Quote from: wizkycho on September 06, 2012, 03:34:15 PM
Of course there is no ADDING energy from back EMF, and if there were not back EMF then all generators would require little force to operate.
What I am looking at is how the back EMF in a shaded pole motor causes a field delay to produce rotation. That same effect may be able to provide a field delay that could offset the balance in a normally symmetrical rotor/stator combination that has the field provided by a permanent magnet.
The idea is to use the back EMF of some windings on the rotor to delay the field at the point the rotor is leaving the stator making for a weaker field to unbalance the system. There is no way the back EMF can affect the rotor because the coils are moving with the rotor and can only push back against the field of the permanent magnet.
In effect it trying to accomplish the same effect you are after by trying to reduce the field strength in one area with another magnet so to cause a rotation.
wizkycho
I have recent threats to my property from "Mr." Ante Karamatić (+385 (0) 98 719 778) Špansko 10 works in Allianz, therefore there is another
allmost proof of concept that FDM works. Yes !
Mr. Karamatić has help from Mardešić Petar that works
M.+385 (0) 98 503 082 Magdalena - klinika za kardiovaskularne bolesti [/b][/size] Medicinskog fakulteta Sveucilišta J.J. Strossmayera u Osijeku Ljudevita Gaja 2
49217 Krapinske Toplice
Croatia
I'll post a movie of their destructive moves.
Igor Knitel
To infinity then another mile
wizkycho
... my previous mail was disturbing
for now seem like it was just missinformed and emotional outburst (not guided by some lobby) of two of my
neighbours ...
After accepting right informations,  emotions have been somewhat normalized
keep up good experimenting
wiz
wizkycho
hy
back to experimenting
  I have been unable to purchase ring magnet for constructing v2 so decided to get small magnets
and make segmented ring magnet. I made only stator.
Experiment showed that static ring magnetic field is rerouted completely, although length of magnetic path is only 20mm.
So one of main principles of work are proven.
Device is not working cause unrouted static ring magnets fields would bend, curve and close their field through
permeable material that is unsloted (incuts). I could make slots wider and longer to streighten (make paths in line) the paths of
segmented magnetic fields, but think that completely segmented permeable parts would be better. This way spacing between
segments could be regulated, and influence between magnetized and nonmagnetized segments lowered.
On the other hand, equilibrium of forces in respect to rotation of prime rotor would be slightly dificult to achieve, which is
other property needed for this to function. But could be done.
Further experiments to come
Wiz
