0 Members and 271 Guests are viewing this topic.
Hoppy
Nick,
Looking at your waveform above, it looks like your choice of capacitor. You should see a better waveform once you get the good quality WIMA caps.
NickZ
  Itsu:
  Ok, I've corrected the winding direction of the ferrite rod, (or the ferrite bar in my case).  It did improve the Kacher's output, and I can now observe a nice HV stream of about 2 to 3 mm, as well as HF stinging felt when touched, which is also stronger than before. Ouch!
  Thanks again...
    I'll connect the probes as you suggest right to the fets, and I'll report back. My Multi meter at the 1000v AC setting is nailed to the right from the grenade's output, without a load. But, with the 3 100w bulbs, it may drop below 1000v. I'll check the meter while running a load, but if I remember correctly my meter was reading just a little less than a 1000v, with a smaller load, kind of like what Ruslan was showing.
  I'll get the scope shots going the way you need to see them.  I just didn't want to short out the fets, as there is very little space left for connecting the probes to the fets. And i only have a couple more fets left, for now. But, I'll show it doing so, anyway.
My 100x probe has got an crock clip on the end of the positive side of the probe, covered with a rubber protector, but also has the plastic shield that can be placed over it, as well. I've also got some twin alligator clips scope probes, but as TK told me not to use them on the Kacher or Mazilli, I haven't done so.
  Looks like my 1x and 10x probes have been purchased and received by my friend in the US, and he will bring them to me on the 22nd, or so, and the WIMA caps are coming, as well.
Jeg
Great video itsu! :) very informative. This clean pulse is very useful!
Tnks
itsu
Quote from: NickZ on September 13, 2015, 02:40:18 PM
Itsu:
  Thanks again...
    I'll connect the probes as you suggest right to the fets, and I'll report back. My Multi meter at the 1000v AC setting is nailed to the right from the grenade's output, without a load. So it's probably even much higher than the 300v, or so,  that the scope is showing. But, with the 3 100w bulbs, it may drop to 300v. I'll check the meter while running a load, but if I remember correctly my meter was reading just a little less than a 1000v, with a smaller load, kind of like what Ruslan was showing.
Nick,   good to know it improved your kacher output, i did not notice that here, but then again, i always used the CW / CCW setup.
Ok, i understand why you don't want to probe the MOSFETs, those crocodile clips are way to big, so don't do it if you are not sure, the main thing is that you are happy with the way the mazilla works now.
Regards Itsu
itsu
Quote from: Hoppy on September 13, 2015, 02:27:26 PM
Nick,
Hoppy,
i understand that Nick will use the Wima caps for connecting in series with the 3 turn secondary, not for tuning the mazilla (but i could be wrong).
Do you think that this MOSFET signal is caused by the used capacitor in the mazilla?
I would expect a half sine wave like signal like in my screenshot (blue trace) not the continued peaks seen on Nicks scope.
What could cause that?  The egg magnet in the yoke which saturates the core/coil?
Regards Itsu
