0 Members and 241 Guests are viewing this topic.
T-1000
Quote from: NickZ on September 24, 2015, 10:42:01 PM
    Let me see if I understand:
    So, first, we need to find the best resonant frequency or peak using a signal generator, of the grenade's output coil.
  Yes, I have access to a SG, but it's not mine, although I can borrow it, but it has no probes. Can any of my scope probes work on the signal generator? I have a probe with twin crock clips, also.
  Then second, the Kacher needs to run at the same frequency as the best grenade resonant frequency (but not the normal running frequency), of the 168 turns coil. So that the Kacher's HV signal will activate and trigger the grenade's output coil at it's favorite sweet spot. This is what had me confused. I get it now.
   And third, the Kacher to grenade/inductor coil frequency ratio needs to be something like 100:1, 50:1, or so. Which for my set up would be the Kacher running at 2.4Mhz, and induction/coil/3turns coil running at 24Khz, or so.  Correct?
  I'm trying to understand what has to happen, and how it has to be done. So, John won't get on my case about not knowing what to do before hand, even though it's true.
First, your grenade coil is the receiver and the wire length defines the frequency. No LC resonance calculations or adjustments in that place as Ruslan insisted all the time. The natural frequency of the transmission line should be looked at.
Second, the Tesla coil is the transmitter coupled over capacitance between top load ("antenna") and inductor on grenade coil. This is where things are interesting as it has to be tuned by wavelength of grenade coil. Ruslan suggested 1/4rd or 1/3rd harmonics. The most important thing there is the Tesla coil is switched on only for very brief period of time for making spikes wih resonant oscilation inside just like he had with nanosecond generator in first versions.
And the third, the series LC resonance on yoke have to be resonant harmonics of grenade coil and Tesla coil. To stay in kilohertz range Ruslan had chosen 1/50th 1/60th or 1/100th frequency. The Tesla coil is enabled and disabled on top of sine wave peaks for spikes with small deviance in tuning for finding best effect.
When you have exactly what Ruslan was saying more details can be looked at..
Cheers!
Dog-One
T-1000,
If you get a moment to do a little more research, see if you can find some material that may explain in radio terms what happens when you modulate a high frequency signal on top of a low frequency carrier wave.  This is essentially what we have with the Ruslan device, but I expect this to behave differently than the common way it does when you have a low frequency signal riding on top of a high frequency carrier wave.  I would like to know what that difference is.  It may explain a lot about how this device needs to be properly tuned.
T-1000
Quote from: Dog-One on September 25, 2015, 04:45:00 AM
T-1000,
http://www.bibliotecapleyades.net/tesla/esp_tesla_20.htm
"...it became apparent that the fireballs resulted form the interaction of two frequencies, a stray higher frequency wave imposed on the lower frequency oscillations of the main circuit.... This condition acts as a trigger which may cause the total energy of the powerful longer wave to be discharged in a infinitesimally small interval of time and the proportionately tremendously great rate of energy movement which cannot confine itself to the metal circuit and is released into surrounding space with inconceivable violence. "
I think this is exactly the same event what N. Tesla described 100 years ago.. ;)
Hoppy
Quote from: T-1000 on September 25, 2015, 04:23:38 AM
Cheers!
Thanks. I understand from previous posts that the natural frequency of the grenade coil needs to be found with the earth wire attached and inductor coil (Tesla Bifilar) wound over the grenade coil. If this is the case where should the frequency generator be attached and should the inductor be loaded and if so with what, when the frequency measurement is taken? I believe Nick is working to the TOPruslan FEG 2014 schematic redrawn by Ibrahim@cicek. This shows a 347.5 metre grenade coil winding length and an 18.75 metre main ground wire for 34.15KHz / 1.736MHz working.
DA1
 Hi NickZ   @ All  สวัสดี NickZ และ ทุกๆท่าน
I look forward to circuit
  With the device
ผมส่งวงจรมาให้ดู  พร้อมตำแหน่งอุปกรณ์
da1
