0 Members and 776 Guests are viewing this topic.
GeoFusion
Hi guyz ;)
I have just  uploaded some good vids yesterday  on my channel for all to see from a previous forum member.
It will help to see what needs to be achieved when system is working.
There are many different ways to make the circuits to make this device work but it's how you hook it up is also important.
And yes, need to let the grenade ring with the kacher.
Btw, No Ruslan Wima Caps used here  ;) just need to know what values you will be using for the experiment
Watch all 3, as it will help to let see how the system behaves.
vid 1 you will see how he turns the system on and yoke is only working but no light,
when connecting kacher ssystem starts working
Vid2
connections are better and minor changes I see and shows difference when removing antenna and with antenna for load.
Vid 1
https://www.youtube.com/watch?v=Qj2Vs_NkURk
Vid 2
https://www.youtube.com/watch?v=1eLAWkXvfQA
Vid3
https://www.youtube.com/watch?v=S2pjHkPNMf0
In Vid 3 it's more perfected with the Effect and getting massive load.
There is measurements also. and putting different loads. Almost at the end of vid, show's HV arc of
end result output.
Schematics are available.
Enjoy.
Cheerz~
Hoppy
Hi Geo,
I think you posted a couple of these videos earlier. This is the guy, URFA, who shows the UPS under the bench and for some reason needs to use this to power a mains PSU. ??? Maybe he suffers from frequent power cuts.
T-1000
Quote from: Hoppy on October 02, 2015, 11:18:50 AM
Hi Geo,
The PSU usually is as the battery source when disconnected from mains from simple reason - the circuits like that generate lots of noise and can feed bak high frequency as the noise back to the mains which everyone would like to avoid. Also, why you wouldn't try make that circuit and verify effects seen in vids instead? Avoiding to get hands dirty? :)
itsu
Quote from: Hoppy on October 02, 2015, 07:36:16 AM
Itsu,
You probably know this, but the switched-mode transformer specified as ERL-35C can be found as the main step-down unit in a PC PSU. The one I tested has a step-down ratio of around 5:1, so can be reversed in operation for step-up working. Although type numbers vary, most can be pressed into use for this application by selecting and measuring and FG scoping for suitable windings.  You should get a nice angry spark at the output with this setup!  :o
I would guess that the 330 should be 330nF rather than pF, as its at the input of the logic gate feeding a comparator (pin 3) from the VCO output (pin 4). So, I think the cap and pot are used for signal conditioning.
Hoppy
Hoppy,
thanks, i did not know that,  good to know, a have some PC PSU's .
All,
thanks for the suggestions on the 330 value,  its 2 for 330nF, 1 for 22nF and 1 for 330pF   :o
Guess i will have to try severall when its working.
Regards Itsu
GeoFusion
Hoppy,
It might be that, but that part is not the main focus.
What we need to focus on is how he manages to get the mixture effect, that is what is most important here now.
The reason he used UPS is to show not using grid power anymore.
T-1000,
I will try it out as how he does it
and see if I can get the same results.
It seems to me a open window we all can use.
the reason I uploaded those vids.
