0 Members and 136 Guests are viewing this topic.
itsu
Quote from: NickZ on October 13, 2015, 09:51:37 AM
  Thanks Itsu. I'll connect the grenade back up to the Mazilli/yoke, and see what the frequency reads on the 3 turns coil, and try to adjust it accordingly by using the turning caps.  I still have 4 turns on the 3 turns coil, so that can also be dropped to 3 turns, if needed to further adjust the frequency.
  I may need to go down to 1.25Mhz for the Kacher's output, as that was where I was also getting the 3mm streamer, and the intense HV stinging was felt. Or the 1.85Mhz, we came up with.
  I have a feeling that all the sweet spots need to be tunes for and found for each device, and not rely on other peoples results.
How's your new push-pull driver coming?
  My head is fine now, as well.  My last post was at midnight, and the spinning was from lack of sleep.
Good to hear it was only temporary   ;D
I still am fumbling around with the PLL and the Kacher drive.
I put the blue box, red box and beige box of the latest ALLEGGA diagram:
http://overunity.com/12736/kapanadze-cousin-dally-free-energy/msg461537/#msg461537
on 1 PCB, but i have a hard time locating the ERL-35C transformer (red box).
Up till now i have opened up 4 PC PSU's and severall other swiched mode PS's, but non contains the ERL-35C
Guess i have to put together one myselve, and/or use the verpies lossless setup.
I can test soon with only 24V on the kacher input, to see if the kacher will run with these small pulses
and how the waveform looks like.  Will complete the 24-130V dc2dc converter lateron
Regards Itsu
Hoppy
Quote from: itsu on October 13, 2015, 10:22:17 AM
Regards Itsu
Most of these PC SM multi-tapped step-down transformers do a similar job, although their type codes vary. You should be able to find a suitable step-up winding configuration using your LCR, FG and scope. I noticed on the Ruslan video recently posted by T1000, that he appears to be using a SM transformer physically smaller than the ERL-35C, which makes sense, as the ERL-35C is overkill for the required output in this application.
Hoppy
AlienGrey
Quote from: Hoppy on October 13, 2015, 10:37:11 AM
Hoppy
Yes well, whats all this then, it's NBG putting a load of AA When We don't have a clue what  your on about.
AlienGrey
Quote from: FreeEnergyInfo on November 04, 2014, 06:49:56 PM
scematic topruslan8 ...
This circuit some kind person has put up, I need to point out to you all that no wave length, tuning information ect and unless you know what you are doing you will never get this unit to work as you will need to set up each individual stage in turn either by adding capacitors or by adding or removing turns, but to what part of what wave, and then their is the feed back circuit.
itsu
Hoppy
Thanks Hoppy,
i guess i have to find a substitute or have to roll my own anyway as the layout of an ERL-35 (which is very hard to find)
does not match with what i need according to the red box diagram, see the picture below, taken from this PDF:
https://www.fairchildsemi.com/reference-designs/RD-268.pdf
Its a 37 turn to 6 turns (or 3+4=7) step-down while i need a step-up.
(or are there different ERL-35 layouts??)
Regards Itsu
