0 Members and 713 Guests are viewing this topic.
itsu
I connected the 130V supply to the Kacher and now we have some better streamer, see picture.
Video here:  https://www.youtube.com/watch?v=dEk_7v3gA48&feature=youtu.be
Regards Itsu
T-1000
Quote from: itsu on October 16, 2015, 11:21:08 AM
Regards Itsu
Good stuff :)
Also before you progress more - do you have good RF grounding for Tesla coil? Due high frequency and skin effect the cable thick as welding cable or the pipe going to the ground would be preffered. This would increase streamers on the Tesla coil even more. Also the frequency change in the Tesla coil will be noticable.
You will need strongest signal from Tesla coil as possible for grenade coil receiver.
Cheers!
itsu
Thanks T-1000,
i have a ground, with thick braided copper wire, but i doubt it will be good enough for RF.
I think that is for most of us a problem.
NickZ could have the best ground as it ends in his water well if i understood correctly.
Regards Itsu
NickZ
  Looking good Itsu. Nice streamer there. Like I wish that mine would do...
  I've thought about running the Kacher coils directly off of the grenade or inductor coil's output. As the grenade output coil, and the Kacher should be in sync. Same frequency or harmonic of it. Or not? Any way, that's still on my mind. I just don't know how to do it, yet. By-passing the Kacher transistor circuit, and use the same frequency that the grenade is already oscillating and running at, feed back to the Kacher coils, but skipping the Kacher drivers circuit.
  Looks like my Kacher wants to run at 1.5Mhz now. That's with a 10 or 20 watt incandescent bulb on the induction circuit, along with the earth ground into my well, yes.  But, I still need more time to figure this out, as there's way too many variables.
  Here's a pic of the 10w bulb glowing off of the Kacher's output, (first image), and the second pic is of the same thing using only one wire connected to the bulb. I guess my hand is serving as the other side to virtual ground. But, I have to take my bare feet off of the floor for it to light up. This is something that I haven't seen up to now. Lighting an incandescent on one wire, but, may NOT work for the members of the "barefoot brigade".
Or, maybe that poor old bulb thinks that it's a CFL.
itsu
Nick,
Quoterunning the Kacher coils directly off of the grenade or inductor coil's output
would be a major change from the original setup if it is possible at all.
I don't think that you should want that, also you need to make it (pulsed) dc, then, the current draw would probably kill the resonance etc.
Nice pictures, especially the bottom one must have been hard to take as i understand you were taking a picture, holding the bulb with one hand and jumping off the floor, all at once!   ;D
Regards Itsu
