0 Members and 346 Guests are viewing this topic.
AlienGrey
Quote from: Jeg on October 20, 2015, 10:17:05 AM
Hi AlienGrey
Nice video, thanks for sharing. Do you have any idea what is this small thing like a capacitor that at 09:02 this guy dismantle from inside his transformer? He called it like..."genister" but i am not sure.
it looks like a cap across the one winding, but could be a battery, who knows.
T-1000
Quote from: itsu on October 20, 2015, 01:39:26 PM
Obviously this 2KV moustache like signal i cannot feed back into the PLL, so it must be dampend.
But dampening it with a resistor transforms the signal to be like the purple one, different shape, but also different phase!
So how do i get this moustache like signal / phase fed back into the PLL?  (voltage divider?)
Thanks,  regards Itsu
For PLL loopback input you need current sense on the yoke input from push-pull circuit. So when there is max current it should be the moment of fire for the Tesla coil.
Also you need to reach power output amplification like in https://www.youtube.com/watch?v=zEBLgIbxP3o where it happen as soon as Tesla coil is getting switched on with fuse to higher voltage into primary coil in video. One thing to mention about ferrite rod on Tesla - Ruslan could not get proper frequency so he lowered Tesla frequency with help of rod there. (And the current sense toroid is seen on 2:31 in the right edge  - also in the https://youtu.be/e3AJ9fy4tB0?t=3m35s on the ground side from the grenade coil)
And the series LC resonance on yoke should not kill itself when you bring more load like it does currently - this indicates problem somewhere in push-pull circuit.
And as always, the power source has to be not from the main grid and not grounded.
P.S> The grounding cable in https://youtu.be/e3AJ9fy4tB0?t=10m38s seems was one from http://www.elandcables.com/cables/h01n2-bs-en-50525-2-81-welding-cable series.
John.K1
Quote from: AlienGrey on October 20, 2015, 02:19:00 PM
Yes he calls it strangely but in fact it is like a SuperCap. As he said, it charge fast and hold the energy for long. In other word, this movie is a parody on self runners. He just showed you how he cheated and he is recommending you not to spend much money for parts as there is nothing for free  ;)
AlienGrey
Quote from: John.K1 on October 20, 2015, 03:06:14 PM
You speak Russian then, and it might be true but if you don't pay for the energy its free. have you looked at SR193 work ?
John.K1
Quote from: AlienGrey on October 20, 2015, 03:33:58 PM
Hi Alien. I am Czech but I speak a bit Russian too. Have no Idea what SR193 means, but I do not agree with that guy anyway. As a simple prove is when I connect two different groundings on my speaker, I have quite load sound output. It is a vibration and it is completely free. Just to find the way to amplify it :)
