0 Members and 18 Guests are viewing this topic.
AlienGrey
Nick have a look at the sr193 video of his device, he uses his mains power supply to start his up, that's off line and it has a ferrite core ??? it's mind boggling whats real and what isn't, with all the ideas going round.
By the way 1.81 mhz is a g good frequency can you maintain it at that frequency, but is the grenade at 18.1 khz and is it in resonance ? you could do with some kind of function generator or DDS to see whats going on with your scope.
sr193 device
https://www.youtube.com/watch?v=rbkvXoDfk7g
AG
Hoppy
Quote from: NickZ on October 31, 2015, 10:01:13 AM
  Hoppy:  Ok, so what do you think that the grenade's self resonant frequency should be running at?
This frequency of 1.81Mhz to 1.85Mhz was what was found with your idea of using a one turn coil placed over the far right side of the grenade.
  Sorry I couldn't get these scope shots to turn around the right way, but you can still see what they are reading.
Nick,
You may have originally scoped into the 1/4 wave frequency, which would put the natural frequency around 7.4MHz. With 1.85MHz, the yoke frequency at 100th division would need to be at 18.5KHz or 30.8KHz at a 60th division.
SolarLab
F.Y.I.
continuation, in part, from my posts:
http://overunity.com/12736/kapanadze-cousin-dally-free-energy/msg464161/#msg464161
and
http://overunity.com/12736/kapanadze-cousin-dally-free-energy/msg455673/#msg455673
Pre-requisite information that will assist in understanding the above referenced posts
(sorry for this omission - a basic assumption on my part that apparently was incorrect).
"Where does the excess energy in Ruslan's [et.al.] device originate
and how does this source relate to these devices?"
Particle (electron) Acceleration {review all the sub-links in the index link below}
"Build a (Virtual) Particle Accelerator" {basic concepts - no math}
http://agni.phys.iit.edu/~vpa/index.html
http://agni.phys.iit.edu/~vpa/accelerator.html
[Used in many FE (CE) devices]
"DC acceleration, Electrostatics"
http://agni.phys.iit.edu/~vpa/dcacceleration.html
[[Possibly more specific to Ruslan (et. al.) devices]]
"Acceleration with alternating electric and magnetic fields"
http://agni.phys.iit.edu/~vpa/electromagnetic.html
"Standing-wave resonant accelerating structures"
http://agni.phys.iit.edu/~vpa/electromagnetic.html#stand
- Again; focus on creating a "compact, smaller, FE (CE) generator" as opposed to a
Megawatt Scientific Research device. Also, recall that thunderstorms (breakaway electrons)
do not need a vacuum nor sophisticated high-tech to function.
Have a fun day [Booo]!
fin.
Hoppy
Quote from: John.K1 on October 31, 2015, 07:17:30 AM
Hi Hoppy. I have now my 2CH signal generator and Oscilloscope connected with the computer and waiting when my buddy will send me a code for the LabView .   I asked him to make two outputs and two inputs. In other word it will generate all combination (up to 5MHz) of frequencies and duty cycles on two outputs and to take the results from the 2CH oscilloscope as a input which will be shown also as a chart on my computer screen. That's the easy one. The harder is to make right decision where tu put my scope probes??  Also I am worry of damage of my scope if it will generate some unexpected high voltage. Should I use some hall effect sensor instead direct connection on the coils than? Any advice?
John,
I can't see how that setup would generate voltages high enough to damage your scope.
NickZ
Quote from: Hoppy on October 31, 2015, 01:10:00 PM
Nick,
  I guess that this might is possible, as my SG is only a 2Mhz model. But as my 3 turn is now running at 25Mhz down from the 28 to 29.6 Mhz that it was at before I removed the two additional tuning caps that were on the 0.47uf cap.  The problem now is that I don't have any more of the HV wima caps,  and placing other lower voltage caps along with the 0.47uf cap drops the voltage to their lower voltage rating.
  Any way, thanks for the reply.
   Alien Grey:  I'm quite familiar with the SR 193 device, as I've discussed it on this thread several times here.
   Why do you think that 1.8Mhz is a good frequency, for my grenade's self resonating frequency?
