0 Members and 407 Guests are viewing this topic.
AlienGrey
Quote from: NickZ on November 17, 2015, 05:43:17 PM
    Itsu:
    Ok, I see. But, the frequency can be changed by removing turns or by adding or removing tuning caps, to some degree.
    I thought that the Mazilli would resonate at the frequency depending on the LC circuit, tuning caps, turn count, etz...  Not at a certain fixed Mazilli running frequency. The 0.68uf Mazilli cap is still not in place, just another cap that is working to some degree.  That cap can change the Mazilli running frequency, but I've only placed another cap that I had on hand there for now instead, which works, but maybe not the best choice.
    I already am using the Mazilli to tune with, but the 3 turns/grenade inductor coil circuit does not even light a small bulb at the 168 coil output, with only the wima 0.47uf cap attached, so it's not in resonance, at all. With one more cap added it start to light the three 100w bulbs, but not very brightly. So, I'll retest again now with all the coils of the Mazilli/yoke/grenade connected up.
   Thanks for the advice.
Nick The Mazilli circuit, you make it sound so easy and stable, it's micro phonic, you only have to fart by it and it's frequency changes, I made the Victor Gero device, https://www.youtube.com/watch?v=anvb_PXG1YA. you need 2 frequency's to get it to work, to do that with this device is impossible! (unless you have fairy dust) all you can do is alter the phase of one of them. after that the frequency of both changes. This device is bull shit. If your using it, i don't see how you can move on, it's an on going saga, never getting any where, the katcher needs tuning and a fixed driver osc running it!
itsu
Quote from: verpies on November 21, 2015, 04:28:38 AM
In this video Ruslan says, that he does not believe that the DSRD nanopulser from Dally's schematic, can generate nanosecond pulses.
He says he can believe in microsecond pulses but not in nanosecond ones....nor pulses approaching 1kV.
Someone who communicates with Ruslan should show him Itsu's video of his DSRD nanopulser, that does all of these things.
P.S.
Where is this video?
Well,   there are severall video's of the nano-pulser output, but with all those video's i have its kind of hard to find  :)
This one shows (second part at the end (5:06)) the working nano-pulser signal being 130V on the drain, 1200V pulse at 13ns wide with a repetition frequency of 2.3Khz which does not heat up anything.
https://www.youtube.com/watch?v=sCF8fwwqhKY
Itsu
Jeg
Quote from: itsu on November 21, 2015, 05:25:07 AM
This one shows (second part at the end) the working nano-pulser signal being 130V on the drain, 1200V pulse at 13ns wide with a repetition frequency of 2.3Khz which does not heat up anything.
Itsu
Your building skills are remarkable.
Also thanks for the pulser info. ;)
verpies
1200V across a 50Ω resistor means that for several nanoseconds this resistor dissipates 28.8kW of power !
Somebody please show this to Ruslan... because at 18:39s of this video he says that this is impossible.
NickZ
  But, would Ruslan really care?
  I still don't get why he would go to all that time and trouble to build the Dally circuit, which is inferior to what he already has.
  Same with the Akula type circuits, using the big Tesla coils and top hats, spewing HF all over the place,  up to one kilometer away.
  I guess that he got bored, or something. Or needed to keep Oleg buzy, with something else to do.
   Akula mentioned in one of his videos that ns is not needed, as ms will do,  to see the "effect".
