0 Members and 528 Guests are viewing this topic.
NickZ
Quote from: AlienGrey on January 01, 2016, 12:44:53 PM
Perhaps, perhaps not, are you going out their to prove it ? The trick is some one else has already done it infarct three have !
   Going out there to prove it has already been done.  Right.
But Hoppy wasn't the one that went to see the "Boys".
And so... He is not a "believer".  Yet.  Nor a member of the barefoot brigade, either.
Nor does he even drink vodka, and smoke, a lot.
All prerequisites...  So, what can you expect...?
  Anyone willing to go see Ruslan and bring back a New Years gift, for us all to be able to replicate from? ??? ??? ???
  Oh, well... maybe someday... This year?
nelsonrochaa
I wish to all people a good 2016 with lot of good new things !
Nick sometimes we have to discover by own like geo show. Maybe replicate something that we dont understand could be very hard and sad ....
i told the same thing  about 4 months ago in this topic, that Ruslan work is in progress too , and that could frustate the people that replicate is circuit .
people after understand the main concept of circuit , should test other configurations  even this could be frustating when results dont appear , but is the deal.😀 if people are just waiting  Ruslan or others share everthing about circuit , they can wait sit in a chair  because they will spend lot of time waiting😡 This is like a game of pride  and conpetition  where money never will be the most important  for this people.
Geo fusion great vídeo ! Thanks  i like the away like you show the things happens in your vídeos ☺
can i ask how many juice is draw in power source? I just ask because in the vídeo the bulbs are very lit not very bright ,
But seems  you feel the joule heat in the bulb even when is not bright  so juice is burning !! Did you measure that ?
I want to know if you have a scope geofusion  because you simple need it !  At some moment you really need know what happen in circuit 😀.
I will donate to you my hantek 6022BE,  is not a Ferrari but for sure will help you  in you research .
Post me in PM please .to give me your adress .
Happy new year for everyone  !!!!!
GeoFusion
Quote from: NickZ on January 01, 2016, 10:10:38 AM
    Geo and All:   Happy New Year...
   After re-watching your last video, I have some observations, and some questions.
   First of all I noticed that your halogen bulb works much much better, than the 60w incandescent bulb.
Is that halogen 220v, or 110v?
   You mentioned that the 28 turns, tuning caps, are placed in series, not the normal parallel way.
Why is that? You're not using the 0.15uf wima caps there? Have you tried any HV 0.15uf cap there in parallel?
   Your push-pull is running off of one mosfet? Or is that a voltage regulator on the heatsink.
   Why are you tuning using low wattage bulbs?  That push-pull won't light the 1000v bulbs that you have?
   Why are you not using your Kacher, to heterodyne the frequencies?  Why the extra long Kacher secondary?
As you know, without the Kacher involved, it's just low efficiency inverter, partially lighting some bulbs.
Happy New Year Nick and All :),
as you listin carefully how I show How I have it all connected ,
try to visualize it thru the mind you will see what I am doing. :) its not hard
With this same Setup which You saw, I managed to get the effect working to a great amount after the disaster of massive output.
It can easily light up 1 KW incad. bulbs, no problems there. 60watt halogen bulb is 120Vac, it light up brighter because of
Thicker filament then the 60 watt incand. bulb. simple , Halogens tend to want more amps than voltage.
Yet I did not connect the Kacher yet in that video because I was first showing many how
and what is happening and where to concentrate on when using pushpull as refreshment for resonance test.
Next vid will come with Kacher and fingers crossed for me to maintain the effect good  this time and having everything connected well.
28 turns output of yoke is connected in *Series* with yoke. and  at the end you have one wire yoke and one wire grenade  that will
be connected with caps in Parallell as always in schematics that is how I have it connect, you can see it.
Only Cap I have in series are with the 3 turn coil for resonance and amplification of output. when shorting the cap in series,
you see bearly no output, it's amazing :)
Direction of how you connect the yoke 28 T with grenade does make a difference too.
If you take a look again at the vids I posted recently of URFA replication of the device,  is the same way I achieved the effect.
Sounds crazy but it's how it is. I will manage to show it and I hope for many of you to follow the same path :) and all will see how to
get there soon.
remember to put 2 Diodes facing to kacher circuit on negative lead, and goes to ground connection of grenade and yoke and one side of the
3T series cap.
Btw, my WIMA 2000V caps are coming, I just ordered with the help of a friend living in Croatia.
But as you can see, you can use other types of caps but not all of them will work, there are specific types that will work,
Its all experimental.
I will get back, See you later guyz :) happy experimenting.
cheerz!~
AlienGrey
Quote from: TinselKoala on September 11, 2015, 03:33:48 PM
Let's see -you- do the same with one Watt. You cannot... and neither can the original claimant. If you could, it would be easy, even trivial, to run ten or a hundred identical devices from the output of the first one in the chain, with excess power left over to run some other practical load. You will _never_ see this demonstrated though. Why not? I know why, Nelson, and so do you.
That's an interesting claim Mr Tinsel, If you go over all the Donald L Smith video's on you tube he claimed he could power a pile of 100 watt bulbs by first starting his device off with a 12 volt battery and was never challenged over his claim. I'm wondering what your thoughts are on this and would be interested to learn if you have ever tested out any of his claims (purely for educational purposes) ?
AG
AlienGrey
Quote from: itsu on December 31, 2015, 12:35:42 PM
Alien,
the grenade has severall resonance ponts, the strongest being around 2650KHz.
I tuned my kacher to 1/2= 1325KHz and 1/3=  883Khz, so in both cases the Grenade resonance frequency was faster.
Itsu
What happens when it's 1/4 wave ?
