0 Members and 125 Guests are viewing this topic.
Jeg
Quote from: itsu on January 21, 2016, 05:15:28 AM
Hi Jeg,
R2,R4 and/or the 1n4148 diodes are taken care for that.
You are very right. Thanks a lot ;)
GeoFusion
Hi there Guyz :).
Had no time to work on the Davice last days, had some matters to take care of. will see If I can get some time on it Today.
My WIMA caps 2000V 0.47 reached :). and  radio material to make into a Spirit Radio finally.
I recently Downloaded a 1.70Gb file from russian Forum.thnk you N20Wolf for links.  I could Upload some to the forum.
Torrent Links
http://realstrannik.com/forum/freeenergylt-antanas/708-povtorenie-ustanovki-free-energi-kolobukhova?limitstart=0
From a Latest update of a person which replicated the device In the same manner as How Akula has his schematic :).
is Sergey :)
He replicated the system, The schematic he drew is so similar as Akula's but easier to understand.
I see now where and how the Effect takes place and I Did not expect what I saw, but it's Brilliant!
The Mediator is the Ferrite YOKE ( any round transformer core )with high Perm.!
With proper connections on the Circuit board of Push-pull and Tesla Nano-sec Gen. and of course
High Voltage capacitors are needed for the effect to take place.
Makes sense now while taking a look at the Schematics and Videos ( High Quality close ups ). at the same time.
Like I said befor guyz, this system is combining External Voltage and External amps to combine together. to form many watts.
Radiant Fusion Generator I would call it.
   Nickz,
The Value of the Diode I used at the power supply is 1N5408, 1000V 3A.
Srry to hear about the smoked Fet. Btw try to find the 1 1/2 inch Toroid, maybe there will be a difference. I soorted out my Fet problem.
But Nick, make sure you have Atleast a TL494 circuit or what Sergey has or Oleg boards. for tuning you will need it.
How do you connect the 22T coil for kacher? Both Negative and Positive leads of the kacher to the 22T coil of mediator?
Or just 1 lead of the 22T to Kacher positive and the negative to the PS?
Tomtech29,
Yes exactly how you see it in the schematic I had it connected just like that.
but changed the Emitter connection to the ground side and saw better effect.
Btw the Voltage at output is 102 Volts, i managed to measure it. but will eat when putting more load,
because the system doesn't have a good high voltage cap yet.
magpwr,
Yes Vasmus System is very different in setup compared to Akula/Ruslan devices, especially the sumator Core is something.
yes kacher is powered by one of the outputs of the sumator coils the nano crystalline plated coiled up core.
I thinking the sumator with the mixing circuit is the Mediator. yes it's like mixing.
Kacher and coiled plate pulser, as you can see they are similar components in these systems
        Cheerz~
NickZ
  Geo:
   I was also busy today and haven't taken the time to work on my device.
   You asked, "How do you connect the 22T coil for kacher? Both Negative and Positive leads of the kacher to the 22T coil of mediator?
Or just 1 lead of the 22T to Kacher positive and the negative to the PS"?
        end quote.
   The ending of the 22T coil on my mediator is not connected to anything,  as it only dimmed the Kacher's output, not brighten it.
The end of the 12 turns coil of the mediator goes to both the Kacher transistor's positive rail, and also to the yoke center tap.
The PS is the negative for both Kacher and the yoke circuits.
  I still need to tune, and adjust things though, once I get it all working again.
  I did notice some kind of sync going on, but would lose it, like as if there wasn't enough power to sustain it.
Also, at times this strong magnetic vibration from the yoke.
And, now I can't get into the "chaotic mode", anymore. So, I'm probably not hitting the right resonant point, yet.
I need more tuning caps in anycase,  but which ones?
  I'll take another look for my 1 1/2 inch green toroid core. Or I'll just  use a smaller yoke with the 12t, and 60t like is recommended.
   Good idea about the yoke being the mediator...
   A yoke with a full circle of thick mag wire, then all the other coils wound on top of that.
I wound a yoke like that at one time, but didn't connect the Kacher up to it, as you're doing.
Dog-One
Quote from: GeoFusion on January 21, 2016, 02:51:04 PM
Torrent Links
is Sergey :)
I finally downloaded the torrent and will continue to seed it for others that may want to investigate.  The schema
looks remarkably simplistic.  There is a hand drawn color highlighted schema that should prove most useful as well
as a new schema computer generated (January 2016).  Be cautious of this new schema as I found a few mistakes
in it already--one being the implementation of the LM2596, which looks to have the output inductor and feedback
mechanism backwards.
The older hand drawn schematic shows all the coils and antenna wound in a clockwise direction except for the last
two segments of the grenade coil.
It does look as though Sergey is working towards a single circuit board solution requiring only the hookup of the large
or power heavy components.  From what I can see, you will only need to connect the power transistors, toroid coil,
high voltage capacitors, diodes and the main coils to have a fully functional system.
I'm still concerned about why all these replications are using massive heatsinks and fans.  Like Nick has mentioned,
if properly sized and tuned, the transistors should be able to run with passive heatsinks just fine.
I found this quote stating a Method of Operation:
Quote from: Anton Dremliyga (AntonW)
Key to the scheme:
There choke coil through which a current is passed to the transformer.  This current creates on reel-throttle
electromagnetic field with salient pole like a permanent magnet, the North and South if the North apply an
electrostatic field, the current consumed by the load will increase from 1A to 3A, if the electrostatic field to
submit the South, the current to 3A drops to 1A.  That is thus throws electrostatics in excess 2A, but
nevertheless these 2A consumed from the power supply.  If you submit a South magnetic field, the 2A that
throws an electrostatic field in the system will be compensated by the magnetic field coils supplied from the
South and not the consumption of 2A power supply.  As a result, the system consumes 1A, and the electrostatic
field and the magnetic field applied to the different poles of the coil-throttle will pop loose in extra 2A.
Explanation of the theory:
An atom of copper as a result of explosive impulses and influences MP pulls itself assume a charge in the
electrostatic field at the same time, the charge must be balanced by another similar charge, but opposite
in sign.  If at a given time will not be submitted to a magnetic field, electrostatic charge compensates the
magnetic charge with the power supply.  Since the magnetic field is applied with respect to a predetermined
time of submission of the electrostatic field, this process takes place synchronously.  and electrostatic charge
compensates for magnetic.  As a result, a copper atom and receives magnetic charge and the electric charge
is uniformly and pulls the magnetic charge from the power source.
https://www.youtube.com/watch?v=jOxdsFsJc7k
So I would have to agree Geo, we have a system that is mixing amperage and voltage from two different
sources giving us real output power.
Dog-One
This is something new, an antenna spark gap.  I wonder how much it helps...?
