0 Members and 125 Guests are viewing this topic.
Tomtech29
Hi.
Guys
sit two days on this system and I can not continue to run it? (would any of you see this scheme and help me)?
I can not find the cause of what is happening
-I have a signal on 74Hc14(74Hc132N) the second leg 29Khz and the sixth leg of the high frequencies(543Khz-5.88Mhz), tune 2K. but after plugging 74HC00 the signal disappears! (He changed a few other 74HC00 and is the same)
I do not have an output from the 74HC00 to control mosfet! (the driver also took out) maybe something  need to change the scheme if what do you suggest?
- use such a scheme:below
if you think that the pattern is fine (OK) should work to let me know I'll be kicking.(I'm starting to worry I could start on the model if it works at all)?
Jeg
Hi JohnK1, Geo
I spent a lot of time to make unipolar pulses at katcher's output. The only way i did it was when i intercepted a diode between katcher coil and antenna, and adding in addition a small cap between antenna and ground. The problem is that the use of diode at this point, kills the HF resonance of kacher, driving it oscillate to a much lower frequency. So i guess this is not the right way. Also, the use of ferrite between katcher and antenna doesn't give any rectification to the pulses. I concluded that ferrite can only shape the form of pulses making them narrower depending on the type of ferrite. But there is no rectification there also.
I wish i am wrong but doesn't look like that we can get something more just by combining HF and Current. It is something more than that. Also for me, there is no way a Tesla coil to be an OU device by itself. A Vacuum pump? Yes you can call it like that, but with expense. You take back no more than what you give to the system. Is there any opposite opinion based on proven facts?
magpwr
Quote from: Tomtech29 on January 22, 2016, 08:40:52 PM
Hi.
Guys
hi Tomtech29 and everyone,
I have attached waveform and circuit diagram as downloaded from the huge torrent related to Sergey.
The circuit diagram was only revealed for a brief moment in one of the Russian video discussion as found in the torrent download.
2 things to note
1)Base on waveform sergey is using 1/100 ratio for the frequency.If the tesla frequency 1.66Mhz the pwm frequency is 16.663khz.The only thing i can't tell if the frequency in Mhz is derived from interrupter pulse ,harmonics or just tesla frequency.
2)Sergey circuit although i got no time to study this it would be likely generating few interrupter pulse say 5...9pulse in a row.
  If you are familiar with tesla coil and interrupter circuit.I think Sergey is running this interrupter pulse at tesla coil resonance but using only 5...9 pulses in a row,in nanosecond.
"Like he is aiming for nearly maximum point and not going further."
Oleg circuit merely generate single nanosecond pulse compared to Sergey's circuit.
But i do find it strange Sergey's circuit did not Superimpose high frequency in Mhz to center tap.Worst there is no choke implemented.Maybe this was his early design.
My last experiment with "Tesla Transponder 2.0" circuit with interrupter pulse (10...20pulse in a row)without kapanadze coil yield max 32Amps to Earth .Power using full bridge rectifier from a high power 12 to 220volts inverter.
Interrupter circuit does produce little better output at a cost of increased current draw.
All the while my primary aim without dabbling further was just to get some spark from the ferrite rod which i had failed miserly."This was the test Akula did before even providing power to the bulbs in the old video"
After watching the recent video of Geofusion.This gave me hope to complete this feat successfully at least. :D :D :D .
John.K1
Hi Jeg, others
I was reading some comments from Ruslan last night and it is now even more confusing.  He says: "  Forget about that stupid pulses, my device work on the principle of mixture of Longitudinal and transverse waves.  How many people has done this?  No one of you!!  ....."
If I understand right, transverse waves are for example- sound. Is any of his coil tuned to the frequency of sound in copper? I know a device which works on this principle and how it works. But this device?  Why didn't he tell us before?  Why is he now speaking about it?  Is it his aim to confuse us?  Why does he says nobody has done it, and in previous posts he says several people made the device?
looking at it from the - other side we have charged particles on our asymmetric capacitor in enough high density and now - accelerate them. Possibly strong enough magnetic field  and transverse waves comes to play its role?
What are your opinion about the principle of this device. Let's elaborate it here together.
Hoppy
Quote from: John.K1 on January 23, 2016, 07:35:24 AM
Hi John,
It has been strongly suggested that Ruslan, Akula and others are seeding disinformation, so its probably best to take what they say with a pinch of salt.
These devices are basically assymetric capacitors, where the earth acts as a return conductor for HF currents when grid connected PSU's are used. T1000 has given good advice by advising experimenters to ditch these PSU's and replace with battery supplies. Surely this makes sense, as the grid should play no part if we are to believe that both Ruslan, Akula and others are demonstrating genuine self-runners. I'm hoping that Geo and Nick take his advice and show their devices running on a battery in any future videos they post. I see nothing unusual about the operation of the devices and the 'effects' I've so far seen demonstrated, where they are powered by grid connected PSU's.
