0 Members and 134 Guests are viewing this topic.
Dog-One
Just a crazy idea here...
Has anyone considered injecting low power white noise into the inductor coil and running an FFT scan on the output of the grenade coil to see what frequency peaks show up?
Looking at the latest Sergey schematics, it is evident he runs the output of the grenade directly to load and does not pass back through the toroid transformer the way Ruslan does.  This seems pretty smart and may be the reason Sergey doesn't need any PLL control since the load cannot influence the toroid transformer causing it to alter frequency as load changes.
Tomtech29
Hello
magpwr
hundred times thanks !!!
-I swapped the chip how did you manage :D (pulses are but as you can see I can not move) Tesla phaze shifter?
Switching to single pulse works and the number of pulses in the package / pulse definitely have so flash?
I would like to remove all the mistakes and make sure that the system works like yours,so check your schedule and you have C2 4,7nF if there is a problem with me is 10nF?
magpwr
Quote from: Tomtech29 on January 29, 2016, 06:32:03 AM
Hello
magpwr
hi Tomtech29,
I'm glad you have tried out the circuit.I do need to allocate free time to assemble the PWM generator on a large veroboard :o after completing soldering the snubber components and mosfets.
The interrupter circuit should be quite close to simulation tools.
I would normally use Mylar polyester capacitors for this type of circuit and usual ceramics for the supply along with electrolytic capacitor.Bought bulk of this Mylar of various values(4 or 5 of same values) which is all thrown in a packet.From ebay China on the cheap.
Base on my previous attachment-
RV1 control the position of interrupter pulse.In virtual it seems i need to control 1k pot to the end.Take note it is also depend on value of C1,R1 is 1.2k.It hard to notice since i had to shrink image.
I may change 1N4148 to sk diodes like 1n5817 or 1n5818 since it produce less jitter than 1n4148 for some reason.sk diode is good for nanosecond pulse width.
RV2 control the number of interrupter pulse to appear(<->)
RV3&RV4 control the intervals between the packet of interrupter pulse and pulse width of individual interrupter pulse.
74HC132 instead of 74HC00 in virtual.I will try out what's the effect of using a 74HC00 in virtual.
Latest update-Only 74HC132 works in virtual.
I have attached a improved version of the Sergey interrupter circuit.From pwm generator dual output 2 diode via 2 maybe 1kresistor need to be connected to circuit  input or can be configured as jumper input with 3 selector which give more control.
Because in my case the pwm generator output will be around 23.5volts , using XL6009(voltage boost) which will be set at 24volts.
Any further improvement will no longer be considered Sergey's circuit. :D :D :D
That's all for tonight.
GeoFusion
Hi Guyz  ;)
magpwr and all
thnx for the updates
and putting minds together :)
All,
Well something interesting has happend yesterday at night yet i still have to record it but guess what guyz :)
I managed to replicate the 100% URFA  effect style :),
Where He passes his hand over the antenna and  Influences the lights to dim or turn very very Bright!
the exact same thing..
Let me explain till the best I can...
It began where I saw some strange behavior while playing with the Duty cycle Var.resistor on pushpull circuit !
I told you all  when tuning the duty cycle to 30% above  it dies? well , I figured out when setting it almost to setting Dying,
there is this unique effect happening to the system :)!
the Mediator started to give a Chaotic Radio Distortion, when where I retuned the freq till I reached a peak where
the bulbs turn on. added more caps and the ground is needed in order for loading and Effect to stay alive!!
when disconnecting the ground there are no lights! and it seems that everything heats up if you leave it disconneted.
Stranger as it gets , now the system is very fragile in freq. but the loading is brilliant :) very different.
When you start up the pushpull, no lights are lit, but when connecting the Kacher to the mediator connection
to the yoke, there the lights come to life!!  :D Only when kacher is connected!!
So, the load is only available now when kacher turns on,  btw I have my WIMA 2000/700 0.47uf caps installed
and unwound the kacher to same size of grenade with extra counter 4 turn befor the ferrite piece.
For the  mediator I am just using the green yellow connection to yoke one , leaving out the other tin winding.
It works!! :) URFA's system is very real as seen in his recordings on youtube.
It seems that everything was on the table... but the trick was never shown how.
It was only a odd tuning that was missing... how weird is that? damn :)
I'll make a recording of this..
When the system was running it froze all my laptop mouse pads, even my touch lamps in house where pulsating
for the first time when Kacher was turned on for the effect, never seen befor....
Guyz Check out Alexee Sergey's Circuit. Take a look :)
                     Cheerz~
Hoppy
Geo,
Good work. You are seeing exactly what I saw with my setup, where you can turn the bulb brightly on and off just by moving your hand close to the antenna. Try monitoring your input current now, to see how it changes with the effect. Also try disconnecting one side of your push-pull. I recall that the effect caused massive interference with my TV which was downstairs. That's as far as I went with experimentation, as I was concerned about damage to my home electronic devices. I may setup again in my garden shed when the Summer arrives.
